Is more than 18 degrees base timing too much?
Old Oct 4, 2005 | 03:19 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Well i am still trying to get my TBI to Carb project up and going right. Only problem i have now is, if i am at a dead stop and i mash the pedal, it takes it a second to get going, it wont even break the tires loose, and from what i understand advanceing the timing should kelp this. I have already got the base timing set at 18 degrees for a total of 36 degrees, if i set it any higher will it be dangerous to the motor?
Old Oct 4, 2005 | 03:54 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
might be a carb problem. not getting enough fuel, not neough vacuum or not enough fuel PSI, but what do i know?
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
bamaboy0323
Sep 3, 2015 06:07 AM
cstrobel65
Aug 15, 2015 10:19 AM
bamaboy0323
Aug 15, 2015 07:20 AM
