rear main seal
Old Oct 4, 2005 | 10:38 PM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
rear main seal
My car is an 84 z28 5.0 HO, but I believe the motor was changed at one point with an 86 block. How do I know if I have a one or two piece rear seal? Im leaking a little bit of oil.
Old Oct 5, 2005 | 04:43 AM
ede's Avatar
ede
getting under it and taking a look might be a good start
Old Oct 5, 2005 | 10:48 AM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
i dont remember if they started using one piece RMS in 86 or 88. pretty sure it was 86. either way, the one piece is seal is gonna be significantly bigger that a 2-pc, and its gonna stick out from the block a little more. i'll see if i can get a pic of mine to post for you.
Old Oct 5, 2005 | 12:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Casting numbers tell all...
Old Oct 5, 2005 | 08:02 PM
Car: 84 Z28
Engine: 305 HO
Where are the casting numbers located? The size is stamped behind the drivers side head correct? like 5.0 L, and up front on the pass head theres supposed to be a number correct? Where are the numbers I should be looking for, and how do i decode them?
Old Oct 6, 2005 | 01:36 AM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
best place to find head/block/crank or any casting number info
MorTec
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
