Car won't hold idle, RPMs drop....
Old Nov 9, 2001 | 10:20 AM
F0xBody50's Avatar
Guys-
I need a little help here...
Last night I washed my car, really briefly (didn't open the hood or touch the engine), and when I went to move it...it started, but the RPMs surged to about 2000, then dropped to 500 (in park)...
I drove around and bit, and each time I slowed down for a stop light, the RPMs would drop to 500...which is really low ain't it?
I could barely hear my engine and the flowmasters it was so low...I knew something was wrong...then this morning, I go to start it, and it fires up, but then dies immeadiately, unless I give it gas...but as soon as I let off the gas...it drops RPMs and dies..
I JUST had a brand new EGR installed by the dealer, so I don't see how I could have a vaccum leak.....I was meaning to get an oil and liquids change today (I put 3,500 miles on it without a change), could that be the problem? Maybe the fuel pump died?
Any help is greatly appreciated, thanks
-ONE2FLY
1990 IROC-Z Camaro
Artic White w/ Gold Decals, 305cid V8 TPI, 700R4 Auto w/ OD, 16" 1992 Z-28 rims (w/ white trim), Z-rated Extremos 245/50/16s (new), Power Options, T-Tops, Tinted Windows, Flowmaster Exhuast w/ High-Flow Cat-Back....
Old Nov 9, 2001 | 10:52 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I don't think 500 rpms is too low some like it around 550 for idle in D. Now in park you'll want it a little higher. I'm not sure on TPI engines but carbs have a screw to adjust your idle.
Only going 3500 miles won't cause your car to have problems running. I would definately look for vacuum leaks, and make sure no water got in the distributor.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
[This message has been edited by Mark A Shields (edited November 09, 2001).]
Old Nov 9, 2001 | 11:04 AM
F0xBody50's Avatar
In Drive or Overdrive, it normally holds steady at 600-700 RPMs, and in Park, it normally holds at 900-1000 RPMs...
I know 500 in Park is low, and it got real stumbly, I'd give it gas, and let off...and it would just fall and die...
Like I said though, it's not like I was messin with the engine AT ALL...it ran PERFECT all day yesterday...
You could be right with regards to water getting somewhere it shouldn't have, because I just went outside and it fired up and held steady RPMs (this is with the engine warmed up).....I drove it around and everything checked out, it ran fine, so I'm pretty sure it's not a vaccum leak, is there anywhere else water could have gotten that would cause this? Thanks man
-ONE2FLY
1990 IROC-Z Camaro
Old Nov 9, 2001 | 04:19 PM
F0xBody50's Avatar
TTT
Nobody else has any ideas?
I drove to work today, and it was perfectly fine, but I would like to know what the problem was this morning, to insure it doesn't happen again...
-ONE2FLY
1990 IROC-Z Camaro
Old Nov 9, 2001 | 09:15 PM
89IROC5.7's Avatar
Car: 89 IROC
Engine: 5.7 TPI
Transmission: A4
I had a similar problem with it starting, surging idle and then dying. I clean the IAC and its passages and lube the worm gear and that fixed it.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
ZsTransAm
Aug 11, 2015 07:30 PM
