torque on head bolts?
Old Nov 9, 2001 | 03:33 AM
poncho9789's Avatar
I am running edelbrock heads I am currently re-installing them on the short block. I put permatex thread sealer on the head bolts (arp) and I torqued them to 75fpt and I was wondering if I should go more, lower, or leave them the same?
89 GTA w/700r4w/stage 2 shift kit,2800 converter, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body, Ported Edelbrock centerbolt heads,Accell 30# injectors,holly afpr,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil,150 shot NOS. My baby is going back togeather soon.
Old Nov 9, 2001 | 06:32 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Factory is 65, most aluminum heads tend to be 70. I would not go any higher than 70.
Old Nov 9, 2001 | 07:25 AM
ede's Avatar
ede
i do what ARP said to do for the bolts that you bought. all the ARP stuff i ever used came with instructions and specs to follow for best results.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 9, 2001 | 03:36 PM
poncho9789's Avatar
ede the problem is that the headbolts I purchaced did not come with the thread sealent so I had to use permatex thread sealent. The arp instructions said to torque to 65 pounds with their bolt lube or their brand sealent. It said that if you use 30w oil to go to 85fpt so I went in the middle is this ok.
Old Nov 9, 2001 | 03:41 PM
ede's Avatar
ede
since you have them torqued i'd leave them as they are. the thread swaler you used would of been or should of been the same as arp sealer.
ICON Motorsports
1st & 3rd
Old Nov 10, 2001 | 01:06 AM
poncho9789's Avatar
thanks guys I called arp today and they said with the sealer I used that I should torque them to 73fps and I torqued them to 75fpt so I should be cool.
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
