Hard start/ Bad gas mileage
Old Oct 7, 2005 | 12:56 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
O.K. Guys hears the deal, I had the timeing chain replaced on my 90 IROC 305 tpi car with 2.73 rear grars. The problem is that now the car starts hard after she is warm, and my gas mileage has dropped a bunch. From about 21 mpg to 14 mpg!!!!! The only thing done differently than stock is the mechanic advanced my cam +2 deg. What can I do to fix this other than tearing it all back apart???? Any help would be great!!!!!! Thanks Mark
Old Oct 7, 2005 | 07:47 PM
sellmanb's Avatar
Car: '86 Berlinetta
You'd have to tear it all apart again to get the mechanical timing to 0.... if the mechanic never asked you if you wanted the timing advanced or retarded, then guess what... that mechanic gets to fix it for yah!
Old Oct 7, 2005 | 11:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Advanced the camshaft itself 2° or the timing 2°? Two very different things. Under the assumption that the timing is what was set, might want to double check that it was set with the EST unplugged.
Old Oct 7, 2005 | 11:33 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Check the coolant temp sensor and the wires going to it for a good connection.
Old Oct 9, 2005 | 08:50 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
No it was the cam advance +2 deg' not the timing.
Have a brand new hypertech coolent temp swith, and it works fine.
This problem started after the timing chain was replaced. Before chain was replace and sloppy as hell the car got 21 mpg, after the chain was replaced and tight, it went down to 14 mpg. This is also 99% freeway driving.
Old Oct 9, 2005 | 09:02 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Take it back and tell them to install your cam straight up like they should have done in the fisrt place.
Old Oct 9, 2005 | 09:27 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Yeah thats what I thought, thanks for all the responses I appreciate it.
Mark
Old Oct 9, 2005 | 10:10 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Was the ECM memory reset so it can relearn the change?
Old Oct 10, 2005 | 11:10 AM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
No the ecm was not reset!!! I am not up on computer controled cars, so how would resetting the ecm change things????
Thanks Mark
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
johanlindgren
Aug 16, 2015 12:16 AM
Bradsaundry
Aug 12, 2015 12:34 AM
