ENGINE CRANKS, but won't fire. '86 TA TPI (stock)
Old Oct 17, 2001 | 10:07 AM
Tom Batts's Avatar
Old Nov 10, 2001 | 07:28 PM
Tom Batts's Avatar
Old Nov 10, 2001 | 07:49 PM
JOHN/88IROCZ's Avatar
you could have a bad coil,or check to see if you are getting power to the coil. make sure that all of your grounds are grounded.chek all of your inline fuses on all the wires under the hood.my guess is that you either blew a inline fuse or lost a ground somewhere. hope this helps you.
john
Old Nov 10, 2001 | 09:35 PM
shrp1's Avatar
my guess is your alarm is the culprit, if you can disconnect it then try it, check to see if the plugs are firing, my guess is they are not.
1989 20th Anniv Turbo Trans Am
minor bolt on upgrades
12.90 @ 110 on REAL radials and street trim.
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
92projectcamaro
Aug 6, 2015 01:20 PM
