How do you remove this?
Old Oct 8, 2005 | 12:38 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
How do you get this bug Hunk of junk connector out of the firewall????
Old Oct 8, 2005 | 12:57 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If that's the primary bulkhead, it's bolted in from the driver compartment.
Old Oct 8, 2005 | 12:59 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
7mm or 8mm bolt in the center pull out the plug. then the female end is helf in by ears? with bolts atching to the firewall I belive
Old Oct 8, 2005 | 03:06 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
when i removed mine, i had a hell of a time with 2 ppl. It's bolted, or riveted, mine was riveted on. I knocked them out with a punch. Then it was clipped, so you had to undo the clips, i broke mine since it was never going back into the car.
Old Oct 8, 2005 | 04:34 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
every one that I've pulled out was held in by a 1/4 or 5/16 bolt in the center from the engine side of the firewall. Loosed it (it wont come all the way out) and then pull the plug out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
