fastest heads n cam swap time?
Old Oct 7, 2005 | 01:06 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
whats the fasest any of you have swapped heads n cam, think it can be done in 4 hours?
Old Oct 7, 2005 | 01:14 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
In car or out of car? Out of car should be no problem. In car may take some time longer.
Old Oct 7, 2005 | 01:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
in car starting tonight think it can be done by tomorrow 5pm?
Old Oct 7, 2005 | 09:45 AM
Stevo's Avatar
Car: Pair of 92 Z28s
lots will prolly say yes it is, but im gonna say no.
If you have never done it before then no. If uve dissasembled a lot of crap before on your motor then its possible.
I know myself it would take me longer then 4 hours.
Old Oct 7, 2005 | 09:47 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes! you can as I see your hsr will make it a bit quicker. most of it depends on your specific setup however I would guess you just have the intake, belt, balancer and pulley, waterpump , valve covers, timming cover, a/c condeser and radiator to remove and reinstall so yes. if you are in desperat need to do it that quick I don't see why not
Old Oct 7, 2005 | 10:22 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
depends on your abilities.
Old Oct 7, 2005 | 11:23 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I'd worry about doing right, rather than how fast.
Old Oct 7, 2005 | 11:58 AM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Old Oct 7, 2005 | 12:43 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
when you put yourself on a time limit you're destined for disaster... something will always pop up unexpectedly, something will always leak, something will always be a PITA to get on/off... well atleast in my world this happens.
Old Oct 7, 2005 | 01:00 PM
jimmy_mac's Avatar
This is the same world I live in. I thought I was alone on this planet.
Old Oct 7, 2005 | 02:55 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Re: fastest heads n cam swap time?
It can be done, but there is no way its gonna happen. I'm gonna say atleast 10 hours. Its all the little **** that takes the time.
Old Oct 7, 2005 | 04:27 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
It took me around 6 hours but I had air tools. It was my first time doing it.
Old Oct 7, 2005 | 04:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Worse case scenario, it took me a Sunday to strip it, a week to get the heads back, put the cam in and cleaned everything up over a couple of weeknights, then bolted everything else back up the next Saturday. Guess you could say 1 week.
My engine compartment though! Can we say, NO room. I would rather do them on a 4th gen LT1.
Old Oct 7, 2005 | 04:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I started swapping a cam in February, and I'm still not finished yet.
Old Oct 7, 2005 | 05:14 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
With my old 305 cam swap took 3 hrs start to finish changing all valvetrain parts (lifters/pushrods/rockers and valve springs) along with cam. I'd add an hour if I were doing heads also. heck they assemble full running engines on TV in 18minutes, so something as simple as a cam swap should'nt take that long
Dont rush though, your going to run into troubles and it'll just make you madder than it should...set aside the day and if your done sooner...your ahead of schedule.
Old Oct 8, 2005 | 12:59 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I highly doubt it. It would take at least a weekend to do unless you have alll the tools/parts right when you need them and do not require breaks.
Old Oct 8, 2005 | 01:19 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
The operative question is what's the hurry? Do you have money bet on this? Only have four hours on a weekend to do this? Quoted someone flat rate? Only get paid flat rate?
Rush yourself and screw something up. If it's a hobby, take the time to check everything over twice.
Old Oct 8, 2005 | 01:54 PM
Dialed_In's Avatar
Old Oct 8, 2005 | 03:40 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
it took me 2 years...
Old Oct 8, 2005 | 04:38 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I did it on and off again in the freezing cold and snow, and I had about 6-8 solid hours into it without help my first time. Second time, engine was out of the car, took me about 5 hours to R&R cam and heads, intake, roller rockers and set their lash. During my downtime at night I was cleaning the parts inside with degreaser.
Don't expect your car to fire up and be drivable for a few or you'll just **** yourself off.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
