Burned floor, insulation by cat converter?
Old Oct 10, 2005 | 09:59 PM
Guest
Guest
Posts: n/a
New one on me.
I dont know how or when this may have happened, but my heater core pissed all over the floor so of course I had to lift the carpet and insulation to clean things up. What I saw after that, never seen before on a thirdgen. I dont have a good camera handy but will tomorrow and I plan on taking some pictures of this nastiness...
Anyway, the floor in about a 1' area is noticably burned as if it got pretty hot. The insulation is also burned, though its more of a discoloration than anything, it still feels like insulation. The underside of the carpet is also discolored in a small ~3" diameter area.
The cats have both been replaced (dual cat car from factory) and who knows, maybe one was clogged and it was running that hot. I also dont know if the floor was heated up during repair or what. I havent had a chance to check the heat sheild either, although I know its there and intact but it may be bent up against the floorboard... that I dont know yet.
Kinda bothers me, last thing I want is the car going up in flames from heat coming off the cat and setting the carpeting on fire.
Old Oct 10, 2005 | 10:13 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
did you possibly bottom out on something and the cat got slammed right up against the floor?
Good thing i dont have a cat
Old Oct 10, 2005 | 10:19 PM
Guest
Guest
Posts: n/a
I never have... but the previous owners... who knows.
Floor isnt dented, not that I see.
Old Oct 11, 2005 | 03:21 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
An overly rich mixture can cause the cat to overheat. I have personally seen a Ford with the carpet on fire from this.
Old Oct 13, 2005 | 01:21 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Hehe was it a mustang? Cause i seen one of them on fire due to "exhaust issues".
Old Oct 13, 2005 | 01:25 PM
Ricktpi's Avatar
Nope, 88 Crown Vic Station Wagon
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
my86bird
Oct 23, 2015 12:20 PM
andy74
Sep 3, 2015 08:41 AM
Exxon Limited
Aug 9, 2015 08:13 PM
