oil pump shaft probs....
Old Oct 12, 2005 | 01:15 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
So, I've got the newly rebuilt engine sitting in the car. The trans is bolted down, starter is bolted up, the carb is in place, the headers are on and I am ready to drop in the distributor. I go to my bench and what do I see...... The oil pump shaft box sitting on the bench, unopened.....
So now the question is, can I sucessfully drop this in from the top and have it engage and snap into place from the top, or am I doomed to pull the carb and try to lift the engine enought to get the oil pan off and pull the oil pump?????
P.S. I am running a hardened steel shaft with the steel jacket instead of the plastic jacket.....
Old Oct 12, 2005 | 04:50 AM
ede's Avatar
ede
i've read on here of people grinding down the shaft to fit. don't think i would, dropping the pan isn't that big a deal.
Old Oct 12, 2005 | 06:25 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
pull the pan. I think we've all done that one before
Old Oct 12, 2005 | 06:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I decided to get the steel shaft after having put the pan on. I don't think I've ever forgotten it, though.
Drop your pan.
It could be worse. You could find out that after you've been driving the car, the oil pump pickup has fallen off again, even though you tack welded it this time.
Happened to somebody I know...
Old Oct 13, 2005 | 05:13 PM
911rsq's Avatar
Transmission: yes
Yeah...that's what I figured....
Pulling the pan in the morning
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
formula_novice
Aug 18, 2015 08:48 PM
