Engine builders, got a question
Old Oct 11, 2005 | 10:55 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I put a set of heads on a short block I've had for a while, torqued the bolts to 25 ft-lbs initially then 45 then 65. The next day I went back over them all and on the very last bolt, on the second head, I was easing on the torque wrench and heard the dreaded "pop" followed by an almost instantanious click from the wrench. I would estimate the bolt turned about 1/16 of a turn. After a couple of choice words I eased on it again and just got the click from the wrench with no turning. Did I crack the bolt hole? Is there a way to determine whether or not I did with out tearing it all the way back down and having it magnafluxed?
Old Oct 11, 2005 | 11:02 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It *could* have possibly been just the head of the bolt spinning on the cyl head under pressure, i have had the same thing happen to me on different things. or maybe it snapped off the end of the bolt, pull it out and see if you still have the whole bolt.
Old Oct 11, 2005 | 11:03 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
You should be able to tell without a magnaflux.
If it were mine,I'd start by pulling that head bolt out completely,and seeing how the threads feel.If they are iffy,pull the head back off.I've found that usually if the threads are jacked,it's visually noticable.There are heli-coil kits available for head bolts,though they are not cheap,might still beat a complete rebuild.
Sounds like a 400SB,thy are known for weak threads.
Old Oct 12, 2005 | 11:06 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Well, I pulled the bolt out and its fine. Threads are all smooth. If the bolt hole cracked it would'nt necesarilly mess up the threads on the bolt would it? I guess I'll go ahead and pull the head back off anyway and see what I can see.
Man, this is a bummer......... This short block IS a new rebuild, block was decked, bored and align honed. All that machine work potentially down the drain, its just a 350 by the way.
Old Oct 12, 2005 | 11:43 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
I just pulled the head off. I can't see a crack but I guess that does'nt mean one is'nt there. Has anyone else heard a pop like this while torqing heads down and not had the bolt hole crack? I've never heard the pop before, but have heard about it and have been told it usually means a cracked bolt hole. What do you think about getting a big magnet and some metal dust for a backyard type of magnaflux?
Old Oct 12, 2005 | 12:19 PM
ede's Avatar
ede
wny not PT it instead of some home made ineffective mag test
Old Oct 12, 2005 | 12:27 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
PT?
Old Oct 12, 2005 | 04:18 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Ohhhhhh, pressure test . Yeah I guess I could do that with it still on the stand. Though I wonder if it would leak with a micrscopic crack that has'nt had the chance to grow with heat and such.
Old Oct 12, 2005 | 04:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
PT = penetrant test
Old Oct 12, 2005 | 05:36 PM
ede's Avatar
ede
Originally posted by Apeiron
PT = penetrant test
sorry i'm use to saying PT and forgot where i was at
Old Oct 12, 2005 | 06:17 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
What is a penetrant test and how do you perform one?
Old Oct 12, 2005 | 06:19 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
What kind of lube are you using on the threads? If you're using the wrong kind or not enough it'll cause the bolt to "jump" as you're torquing it. Stock head bolts you can use motor oil on the threads and under the head, and make sure to use sealant, and with ARP's you want to use their moly that they supply.
Old Oct 12, 2005 | 06:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Penetrant testing uses a penetrating dye that seeps into cracks and is revealed with a developer or an ultraviolet light to make it fluoresce. Magnaflux makes Zyglo which uses UV fluorescence, and Spotcheck which uses a developer.
The noise could have just been from breaking stiction though.
Old Oct 12, 2005 | 08:05 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Thanks Apeiron, I think I'm gonna go ahead with one of those tests, I've never heard a noise like that before with clean threads, new bolts and thread sealant.
Old Oct 14, 2005 | 03:03 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Can anyone point me in the right direction to find a spotcheck jr kit. I just moved and no one local seems to carry it.
Old Oct 14, 2005 | 03:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://www.magnaflux.com/sales/sales.asp
Domestic Reps/Distributors: MO
B.C. MacDonald & Company Sales Team
1265 Research Blvd.
St. Louis, MO 63132
Covering: mo
phone: 314-993-2833
fax: 314-993-0405
304 East 32nd Street
Joplin, MO 64801
Covering: mo
phone: 417-624-2150
fax: 417-624-4130
Old Oct 15, 2005 | 10:50 PM
Irockz's Avatar
GMGOD,PM me your phone #,I can hook you up with a dye/penetrant test.Lest ye forget,your living in the stainless steel capital of the US!
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
