advice on electric water pumps
Old Nov 12, 2001 | 07:10 PM
jethro's Avatar
ok, I am converting my 87 IROC 5.7 to a serpentine system... have the parts off a later model... but what about water pump... my old one won't work because of rotation... NOW: what do I do? Do I replace my pump with a new one for later model camaro with the right rotation, OR... do I get one of those electric pumps advertised all the time... and do I now upgrade my alternator... come on guys, I'm counting on you... pros and cons.
ADVICE please:
Old Nov 12, 2001 | 07:33 PM
superstreet's Avatar
Is this a street driven car?If it is,I wouldn't use an electric water pump,they are really only for short durations like drag racing.Is the rotation now reverse?You can run the coolant flow either way as long as the pump is rotating the way the pump is designed.I have a '91 Z-28 that had a reverse rotation water pump and replaced it with an electric,now it flows the opposite(I drag race it only).Reverse rotation is supposed to cool better,but the clockwise rotation will cool just fine.
Old Nov 12, 2001 | 08:42 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Do not buy an electric pump, period.
Now that's taken care of you will have to get a reverse rotation pump from 88-92. Do not confuse this pump with a reverse flow of the LT1, totally differant beast. You can get a stock replacement lifetime new pump from the parts store for under $20 OR, get a performance pump from Stewart for $69 and have it outperform a stock pump 100%!
Here's the link. Part number 13123 all the way to the bottom. http://www.stewartcomponents.com/chevyS1.htm
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Nov 13, 2001 | 07:46 AM
jethro's Avatar
Man, John... that is exactly the kind of advice I needed! LOL... reminds me of my Dad... he was a great guy, and I miss him every day on this planet... Thanks!
Jethro
1987 IROC Z 13.92 and 1.92 60' street tires stock engine
Old Nov 13, 2001 | 08:36 AM
scauffiel's Avatar
I run an Aerospace Engineering electric water pump on my fairly hot 383 with no problems. It's my daily driver as well.
Steve
Steve's Trans Am Temple
Old Nov 13, 2001 | 07:35 PM
Engine: 4.0L
Here's why I said never run an electric pump on a street engine. It's a comparason of the Stewart pump vs. the Edelbrock one. The Stewart put out 18GPM at idle and shot over 100GPM at 4500RPM! That's flow baby, and it's just the Stage 1 they tested. The Stage 4 pump puts out 34GPM minuimum.
the most I've eber seen an electric pump rated at was 25GMP, not bad at idle but that's all you get since it's electric.
here's the link.
http://www.stewartcomponents.com/ede...comparison.htm
86 Camaro Sport
LT1 Induction
My Camaro Project
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
