What have you done to make your lights brighter?
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have an 83 Z-28. The lights have always looked dim or yellowish. I have seen some aftermarket lights that claim that they are brighter but they are just the bulb inserts. Does anyone make the whole headlights for camaros?
Also, I have found a new type of wiring harness that offers less resistance for more power to the headlights. How much would this help? I would rather just replace the lights than to rewire them. Thanks in advance.
I had the same problem with the lights on my 87 Iroc. I got replacement halogen bulbs at kmart for about $8 each. they were white halogens by sylvana, and they made a huge diffrence. I can actually see things with my low beams on. I also tinkered with the alignment of the beams, that helped out also.
Axle/Gears: 3.45, 3.27, 3.27
M.A.D. Enterprises Universal Relay kit. http://www.2xtreme.net/madmark/documents/catalogfs.html
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
(626)369-0040
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I've experience the same problem, they sell new headlights at most auto parts stores, for about 10-15 bux. On my TA I replaced both the headlights with new ones and replaced my foglights with headlights, smaller ones and wired them direct to the battery on a toggle switch. This helped me out a lot, with the extra light from where the foglights would be I can see pretty good at night and I think that wiring the extra lights direct to the battery made them brighter. Hope this helps.
92camaroJoe
Aug 13, 2015 06:07 AM
