Is there a way to soften my gas pedel up?
Old Nov 13, 2001 | 02:53 PM
DiecastZ28's Avatar
My gas pedel is extremly stiff. You have to like stand on it to rev it... Not that bad.. I have an 85' Camaro Z-28.
Old Nov 13, 2001 | 02:58 PM
Joshua Leslie's Avatar
its proly ur throttle return spring, its to tight, or stretched to far, get an aftermarket return bracket and spring.
Old Nov 13, 2001 | 04:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The bushings for the linkage could also be shot. Pop the throttle cable off the linkage (don't lose that damned clip!), and work the linkage by hand... see how it acts.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 13, 2001 | 07:46 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by DiecastZ28:
My gas pedel is extremly stiff. You have to like stand on it to rev it... Not that bad.. I have an 85' Camaro Z-28.</font>
throttle cable might be binding inside the covering. the way to find out is to diconnect the cable from the TB and pull it back and forth. should be no resistance except for the weight of the gas pedal. if there is no resistance, then chech the TB for excessive force to turn by hand.
Old Nov 13, 2001 | 10:10 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
What carb are you running?I had an edelbrock performer on my car for awhile and found it real stiff.I had to set up another spring to pull back against the two that pulled it forward.NEVER run just one spring,you always need two just in case one should fail.I've also seen some Q-jets use up to three springs,if so,take one out or try to mix and match untill you like the feel of it.Hope this helps.
86'Camaro Berlinetta SC,former 2.8,now 350 cid,4 bolt main.94'TPI 350 heads(pocket ported),420-442 lift summit cam,cloyes double roller timing set,Modified q-jet carb(e hanger,ch rods)700-r trans(rebuilt)3:42 gears,t-tops,b&m megashifter,grant wheel,fresh headliner,Macewen white face gauges,American racing wheels..Dedicated to those who enjoy scrounging through junkyards more than throwing money for new stuff...
Old Nov 14, 2001 | 06:17 AM
DiecastZ28's Avatar
I don't know what kind it is, but its a 4-barrel if that is any help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
