Dead 91 RS
Old Nov 13, 2001 | 07:27 AM
91RS GUAM's Avatar
Dead 91 RS
I could use a little help. My 91 RS just died. No power to anything except heaqdlights. Gauges dont work, neither does the horn or warning buzzer. Changed the battery same prob. Happened while I was driving. V.A.T.S./ECM?
Old Nov 13, 2001 | 07:39 AM
Blue92's Avatar
Have you checked the altenator. A car dying while driving is usually a sign of an alt. gone bad. Check it out.
Later
Pics of my Car
http://photos.lycos.com/PhotoCShare/PhotoAlbum.asp?CG=otteftncpeg4ddkiansjgvi7gc&AI D=247820
305TBI, EDL strut tower brace w/spohn SFC's on the way and wonderbar, ASCD big block hood,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
[This message has been edited by Blue92 (edited November 13, 2001).]
Old Nov 13, 2001 | 10:20 AM
82camaro's Avatar
Car: 82 camaro SC
Fuseable link? Have you check that yet. Check all the wires that are near the starter. I'm sure you have checked the fuses.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 13, 2001 | 11:49 AM
leirch's Avatar
Be sure to check ALL of your fuses and as mentioned, fuseable links are always a good place to check.
Brendan
Old Nov 13, 2001 | 05:42 PM
MONTYR1's Avatar
Maybe check the negative cable + see if you have a good ground.
Old Nov 14, 2001 | 08:52 AM
91RS GUAM's Avatar
Thanks guys for the insight. First thing I checked was all the fuses and fusible links. Changed out the computer box alternator, battery same problem. Had it diagnosed, and ran a hot wire to the vats everything works but vats fuse keeps blowing so there is a short in the vats. Anyone know how to bypass the vats altogether? I appreciate the help, and this site has been a lifesaver.
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
Jonas Earl
Sep 27, 2015 07:39 AM
Johnoooooo
Sep 22, 2015 08:55 AM
