what is my car going to run in a 1/4??????????
what do you think my car is going to run in the 1/4
it is a 82 camaro with a 1984 305 H.O. out of a z-28 it has a 2 1/2 inch exhaust with no cat. and a FLowTech Terminator muffler.
a th 400 tranny with a 3.08 rear end
what do you think it will run it the 1/4 mile
thanks
thanks
I'd say mid 20's... joking, I have no idea.. maybe low 15's???? take it to the quarter mile... or find someone with one of those cheesy G-Tech's to give ya an estimate.. the only thing is it told my friend he ran 8.something in his TA and he actually ran 12s
~1985 Camaro Z28~
V8,305,700R4,K&N Edlebrock Air Filter,& MSD 8.5MM Super conductor Wires,
[This message has been edited by FAST85Z28 (edited November 14, 2001).]
~1985 Camaro Z28~
Car: 99 Formula
Axle/Gears: 342
<font face="Verdana, Arial" size="2">Originally posted by FAST85Z28:
</font>
</font>
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
U sure it has a TH400?. You would had to have performed quite a few mods to get a th400 to fit. Like the crossmember relocated, the drive shaft yoke changed to a larger size and done something with the torque arm.
yes it is a th 400
i did all of those things to make it fix
C man
motor was a 2.8L v6 now it is
a 305 H.O. with
a th400 trany.
chrisblaster.homestead.com
my car pagewwwhomesteadcomcman.homestead.com/car.html
C man
a 305 H.O. with
a th400 trany.
Car: 1984 Camaro Z28
Engine: Blueprint 383
A stock '84 Z28 did 15.2 in the quarter at about 89mph according to the Chevrolet brochure. With a TH400 and the 3.08 gears I would say high 15's, low 16's.
To tempest68,
The 305HO IS one of the best 305's that were put in the camaros, Esp. comparing the carbureted 305's.
Craig
84 Z28 305HO, 5spd, 222,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter, 14.630 at 93.17mph
Del-A-lum front control arm bushings, Moog ball-joints, Energy suspension front sway bar end links, Moog rear sway bar end links, Eibach pro-kit springs, tokico shocks/struts, AU secondary rods
www.indycamaro.com
To tempest68,
Craig
www.indycamaro.com
Somewhere between 0 and 25 seconds. The only way to know is to run it.
You have walked onto the biggest baddest dog porch and you will be dealt with accordingly.
I'd rather be historically accurate than politically correct!
1992 Trans Am
Aug 8, 2015 08:16 PM
