Engine dies then will not start
Old Oct 16, 2005 | 03:21 PM
silverbullet86's Avatar
Car: 86 trans am
Engine: 305 tpi
Axle/Gears: 3.27 9 bolt posi
I have a 86 trans am with a 305 tpi and it ran fine earlier in the day but I went to start it this afternoon it started and ran for a few seconds then died and tried to start it again and cranked on it for 10 seconds and it almost started a few times. I waited a few minutes and tried again and it started and ran fine for a few seconds and died again.
I don't know what to do and any suggestions would be helpful.
Old Oct 16, 2005 | 03:25 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
how many miles are on it?
Old Oct 16, 2005 | 03:44 PM
Car: 86 trans am
Engine: 305 tpi
It has 79,000 miles on it.
Old Oct 16, 2005 | 04:18 PM
Car: 86 trans am
Engine: 305 tpi
I just tried to start it again and it started and I pumped the throttle and I can keep it running and soon as I quit pumping the throttle it will idle up and then shut off.
Old Oct 16, 2005 | 04:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Check your fuel pressure when it's doing this. Also watch the fuel pressure after you turn the engine off (or after it dies out).
Old Oct 16, 2005 | 04:35 PM
Car: 86 trans am
Engine: 305 tpi
I have a AFPR and when its running it has 50psi and after it shuts off it slowly falls off to 20psi and stays there.
Old Oct 16, 2005 | 07:41 PM
Car: 86 trans am
Engine: 305 tpi
I found the problom, it was a maf sensor.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
