coolant leak inside the car!!
Old Nov 15, 2001 | 04:52 PM
johndinu's Avatar
Car: '89 GTA 350 hardtop
Hi!
this morning I've noticed a small leak of coolant from under the dash (passager side).It looked green-yellow, very oily. These days I've used the heater and a/c. Any ideea how I can fix that?
'89 GTA
Flowmaster animal
Old Nov 15, 2001 | 04:55 PM
1982chevycamaroz28's Avatar
ur heater core is goin u have to replace it before u get a big puddle like the way my brother found out his went.
Old Nov 15, 2001 | 05:08 PM
johndinu's Avatar
is it expensive? where can I get one?
I can change it myself?
Thanks alot!
'89 GTA
Flowmaster animal
Old Nov 15, 2001 | 05:17 PM
SoCo80p's Avatar
its not too bad price wise and a little of a bitch to swap, you have to pull the heater box off the firewall and swap it.
Old Nov 15, 2001 | 06:56 PM
RODS92Z's Avatar
You have to move the center console back and take apart half the dash to get to it. You can't access it from the firewall. It's a real pain. Expect to spend all day on it.
1992 Camaro Z-28 custom 25th anniversary, 5.7 TPI auto, 2.73 posi, t-tops, arctic white with 92' medium mettalic gray stripes with black border stripe.
1967 Pontiac Catalina 2 door fastback, 400 v-8, auto, cameo white, dark red interior
1987 Olds Cutlass, 350 Rocket, auto, dark gray/light gray interior
Old Nov 15, 2001 | 09:57 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It costs about $40. Word of advice. Take out the old one and go to the store to match it exactly. Both Vader and I, have had the same problem, they looked up the part # and we both got home to install it, but the pipes were at a slightly different angle. I tried to bend them slightly but it wouldn't work. I took the old one back with me and none of the ones at Trak Auto and went to the local store, they had the right one. And on my car, all I had to do was remove a black panel under the pass. dash. I didn't have to touch anything else. Took 30-45 mins.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 15, 2001 | 11:32 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
I just did mine a couple weeks ago (only to find out the old core was not the problem).
I had heard lots of horror stories about the swap, but it's not all that bad. Unless your time is really valuable, don't pay a shop $500 for all the labor (esp. since the core is only $40!), it's not that compliacted. Just take your time, take the seats out to make it easier to get to everything, then take apart everythingin the front of your interior until you can wiggle the core out of its plastic box... good luck. The work took me about 7 hours total; you could go faster by keeping good track of all the screws and pieces you remove because putting it all back together takes a little longer if you don't...
Old Nov 16, 2001 | 12:57 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
you don't have to remove the dash... the tricky thing is getting to one of the srews at the top... using a mirror and the right length og 1/4 in drive extentions does it every time... you may have one extra screw left over when your done though ...
zroc
Old Nov 16, 2001 | 05:10 PM
johndinu's Avatar
Thanks for the useful advice!
When I keep the vent/heat off, the heater valve keeps the coolant from reaching the heater core, so I'm safe for now. Later in the winter I'm gonna replace the speakers also so I'm still gonna take out the top of the dash... this is gonna make things a lot easier!
Thanks again
'89 GTA
Flowmaster animal
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Kaweh
Aug 9, 2015 02:54 PM
