Instrument panel and low beams?...
Old Nov 16, 2001 | 10:02 PM
ChevyLuva3's Avatar
What does it mean if the instrument panel including all the(back lit lights) like the 'ometers, the stereo, etc. and the low beam head lights (first click out) don't work in a Camaro? Is that a fuse? Or the switch? Or what? How can that be fixed?
Any help is appreciated, thanks.
Old Nov 16, 2001 | 10:58 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
Sounds like a short to me, maybe a bad ground. If it happens when you click the low beams on, I would check the wiring there first. Also you may want to check the headlight switch. I hear when they start to go they can cause all kinds of gremlins.
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns w/baffles removed, Throttle body airfoil.
"The reason most import drivers only focus on looking fast is so they can sit there staring at their car and dream about it being fast, because there's no way for them to match American muscle."
Old Nov 17, 2001 | 09:11 PM
ChevyLuva3's Avatar
Yup, gremlins indeed. While I was at work, my bro was tryin to fix the problem, it was a bad switch. It seems the person who owned it before messed up wires. But after that, other lights wouldn't work, it started blowing more fuses, and he had to disconnect a lot of things. The low beams and instru panel works, but the interior, neon, and other lights don't work. An "electrical nightmare" as my bro said. But it'll be alright, if my bro can't do it, my friend can he's an "electrical expert".
[This message has been edited by ChevyLuva3 (edited November 17, 2001).]
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
C409
Sep 23, 2015 04:30 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
