Oil coller on L98
Old Oct 21, 2005 | 12:12 AM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
Oil coller on L98
Hey guys i'm wondering if i can remove my oil cooler that the oil filter goes on? i checked it out and it seems like i can just remove that and just thread it in. can this be done or do i need that? i need the clearance because the oil filter rubs my long tubes.
Old Oct 21, 2005 | 12:14 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can remove it but you'll need to do something with the coolant lines.
Old Oct 21, 2005 | 12:29 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Isn't the factory oil cooler the last thing the coolant reaches before it returns to the radiator??? If so, the concept seems very inefficient. Anyway, I just removed the rubber hose running to the metal cooler line from the rad and hooked it directly to the metal line on the passenger side coming from the heater core. Then I had to cut the metal lines off. How does the cooler come off anyway? Does it just screw off? And can it be done without removing the flexplate?
Old Oct 21, 2005 | 07:28 AM
OneBadZ4U's Avatar
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
Very true! The cooler adapter is held in with a tube that screws into the oil filter adapter(the same that's on other small block chevy's). It is easy to remove, just unscrew it. The problem you will be left with is that the bolt have taller heads that hold the adapter plate in place. So you can't just screw a new oil filter on. You will need to replace the bolts and then you'll be in business.
Old Oct 21, 2005 | 12:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Inefficient in what way?
Old Oct 21, 2005 | 05:30 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
How about 'less effecient' than if it was actually cool water that had left the radiator that went to the oil cooler instead of hotter water that has just left the engine.
Old Oct 21, 2005 | 06:16 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
so how do i mount the oil filter to the engine without the oil cooler?
Old Oct 21, 2005 | 08:52 PM
llvll4l2c91350's Avatar
i had this same problem. took off the adapter then realized i couldnt just screw on a filter. i just put the adapter back on but got rid of all the coolant lines.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
Tarizza
Sep 24, 2015 12:57 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
