car wants to die when cold
Old Oct 23, 2005 | 07:46 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
alright ive got an 88 iroc that ive had for almost a year now. it has been smoking on startup since a couple months after i got it. but when it the car has gotten cold and i try to crank it, it wants to die. the rpms stay real low like between 500 and 1000 and it wants to shut off. Once i drive it and get it warmed up it runs fine. anyone have any idea what the problem is? its not throwing any codes so im not sure what it would be.
Old Oct 23, 2005 | 09:06 PM
Vader's Avatar
Is the IAC moving? At all?
Old Oct 24, 2005 | 06:36 PM
Car: 88 IROC
i havent looked under the hood when it does it b/c im usually late for school in the morning when it does it. do you think the iac is the prob.?
Old Oct 24, 2005 | 08:54 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
thats the same problem im having and ive been told over and over that its the iac and needs a good cleaning. does it sometimes stall going into gear? or idle really high in park when its warmer out (or just when the car isnt cold).
Old Oct 24, 2005 | 10:25 PM
Car: 88 IROC
yes it will sometimes stall but not going into a gear it does it when it is already in a gear. and yes it does idle high in park after the car has been running it idles about 1200 to 1500 rpm's. what all is involved in cleaning the iac? or is that not my problem.
Old Oct 25, 2005 | 05:53 AM
ZZ4 86 Z28's Avatar
it sounds like the problem. i havent done it yet though. ill probably do it this week though. just get some carb cleaner to clean it with.
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
drathaar907
Aug 6, 2015 04:20 PM
