this cam came in this iroc block..
Old Nov 19, 2001 | 11:51 AM
92zeddar's Avatar
Hey guys tell me what you think about this cam I got in this block assembly...
Wolverine 208/212 dur@.050
advertised 270/280
intake .450
exhaust .462
112 LSA
tell me what you think... How much is it worth? and will i have problems with emissions and will i have to run it with a chip?
92 z-28 G92 black with white racing stripes.
Dynomax cat back
Ram air
305 5 speed, underdrive pulleys and TB by pass
https://www.thirdgen.org/rides/rideimages/92_Z.jpg
Old Nov 19, 2001 | 12:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ditch it.
It has too much "advertised" duration compared to .050" duration (i.e., the valves are made to "leak" for a subsantial time, which hurts performance). It doesn't really have enough lift; more lift is always a good thing, up to the mechanical limit of the heads and valve train; you should shoot for around .475" to .480" if the valve train is stock.
That cam lacks what some people call "intensity". It's "lazy".
ICON Motorsports
Old Nov 19, 2001 | 01:10 PM
92zeddar's Avatar
yeah but I was thinking of putting 1.6 roller rockers on it....
Dynomax cat back
Ram air
Old Nov 19, 2001 | 01:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Still has too much "advertised" duration compared to its .050" duration, a worse problem than lack of lift... you'll lose the race (badly) against somebody with an otherwise identical motor but a better designed cam.
ICON Motorsports
Old Nov 19, 2001 | 01:15 PM
92zeddar's Avatar
what do you recommend? ZZ4 cam probally!
Dynomax cat back
Ram air
Old Nov 19, 2001 | 01:16 PM
92zeddar's Avatar
the iroc it was in ran 13.1 so it can't be all that bad...
Dynomax cat back
Ram air
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
