mixed pistons in same block.
Old Oct 24, 2005 | 09:39 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Was at the junk yard yesterday getting some PS brackets. Luckily they finaly had a V8. Of course it was stripped to the bare block and pistons. Funny thing is, the block had 6 flat top pistons with valve releifes and 2 dished pistons (3 & 4 cyl)...is this come crazy secret I dont know about?
Old Oct 24, 2005 | 09:56 AM
Umm, yeah... how to make a motor run like crap with no hope of rectifying it, short of a complete teardown and rebuild....
No wonder it was stripped to the short block, and the short block was left sitting there. I don't think I'd even want anything that was bolted up to that, no telling what other stupidity somebody had victimized it with.
Old Oct 24, 2005 | 10:07 AM
Car: 88 Camaro
Engine: 310 LG4
my thoughts exactly, we were in awe of this. I only needed brackets, so it doesnt matter. I need to mechanical parts from it. I should have checked to see what block it was...
Old Nov 6, 2005 | 06:09 PM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
My Old Man bought a 78 Chevy truck years ago from a guy he worked with-prestine body with a rebuilt 350-You know where this is going. Went to look at truck and it had a bad knock (sounded more like a miss). Dad and I figured ignition problem because it was missing at all RPMs and had sat for about a year. Long story short, after several nights of working on the iginition and getting nowhere we decided to take the whole thing apart and see what was the matter. Pulled heads and found a cylinder with a domed piston and 7 flat tops! I was f#cking stunned, couldn't believe someone would do something this dumb! Computed compression was 14 to 1, no wonder it was knocking. Put new pistons in it and been driving it to shows every since.
Some people should have a pad lock on thier hoods so they can't work on it!
Old Nov 6, 2005 | 06:23 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
I have seen that before but it was dome tops, and flat tops.. they had it so that part of the firing order had more compression than the other. Like every other cylinder in the firing order. Not a good idea.. You may want a different block
Old Nov 6, 2005 | 06:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I imagine the mixed pistons would make a hella vibration due to differences in weight.
Old Nov 6, 2005 | 07:05 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
BWAHAHAHAHA...man this is good.
Check this out....this guy I work with John, he worked with this guy up in New York..said the guy was a drunkard and cheap as hell. Well he had this old *** motor in a car...some 70's car with an I-6, I dont remember the exact details. Long story short, this guy needed some work on one cylinder...what did he do instead? He pulled the piston and conn. rod for that cylinder off of the crank, and bolted it all back together. When it vibed real bad, he found the cylinder most opposed to that one and yanked it off too....
Old Nov 6, 2005 | 07:40 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
My grandfather did a simialr thing on a 350.
A rod bearing was going so he pulled the rod and piston out, shoved a piece of tree down the cylinder and pulled the rockers for that cylinder. sold the truck for $1500, said it needed a carb job
Old Nov 6, 2005 | 07:48 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I hope that guy driving the new truck loses control and crashes head on into him. What a scumbag.
Old Nov 6, 2005 | 08:11 PM
patRIOTik's Avatar
Car: 1986 Chevy Camaro Z28
Engine: 4BBL 350
Old Nov 6, 2005 | 08:17 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Well if the guy paid 1500 for that old hunk of junk he was braindead anyways. i dont think that rust bucket would be worth that with a new engine in it.
I dont think he ever heard back from the guy who bought it though, probably drove it till it dropped.
Old Nov 6, 2005 | 08:54 PM
86TA355SR's Avatar
Glad to hear that I'm not the only one who meets idiots...
Old Nov 6, 2005 | 08:59 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Idiots are plentiful these days!
MrPackstin
Oct 25, 2017 08:09 PM
LT1Formula
Oct 8, 2015 08:34 PM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
rusty vango
Sep 29, 2015 02:44 PM
