open element problem
Old Nov 18, 2001 | 05:39 PM
korbin's Avatar
after installing it, it runs great!! problem is, now the SERVICE engine soon light comes on after running the engine for like 5 minutes or so.... i just had a checkup and they told me that the open element is making my engine run harder.... how can i fix the light cuz i think the gm dealer is full of shyte....
Old Nov 18, 2001 | 07:32 PM
Enkil's Avatar
What code are you getting?
Also, there's a sensor that used to be in the air filter. What'd you do with that?
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Nov 18, 2001 | 08:28 PM
killer305's Avatar
like enkil said there is a wire going to the back of the stock aircleaner, look in the tech artical about open element installation, and they say that if you dont connect the wire then you will get a ses light. i think the dealer if full of it, they want you to give them 65$ an hour to reinstall your old one, of corse something will be wrong with that, and you will have to buy a new one, and it will probably take them a couple hour to install it, you should try to get a output code reader or whatever they are called, if your engine is running to "hard" then it would show up. i dont know how air into your motor can be a bad thing
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
Old Nov 18, 2001 | 09:27 PM
Enkil's Avatar
Well, too much air and not enough fuel will cause detonation, but I highly doubt that's going on here. heh
89 iroc-z 305 tbi
Old Nov 19, 2001 | 08:05 AM
Trent257's Avatar
yea, you have to take that sensor and put it somewhere cold, also you have to plug up the vaccum line, after that you sholdnt see any lights
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 19, 2001 | 08:48 AM
korbin's Avatar
thanks guys but how do i hook the sensor up to something cold and plug the line??? i don't know the code cuz i haven't had anyone hook anything up to the computer...
Old Nov 19, 2001 | 09:39 AM
Enkil's Avatar
All's you need to get the code is a paperclip. (There's a technical article on how to do this.)
Anyways, on the old air filter case, there shoudl be an electrical wire running to a sensor that's stuck in the air filter, and a vacuum hose that runs to the thermac. (That round cap sticking out of the arm of the air filter.) The vacuum hose needs to be capped. As for the sensor, to get the old air filter off you had to unplug the wire from the sensor. Wiggle the sensor out of the air filter. (This might take a little force.) Then, you can either put it in the open element air filter (punch a hole in the metal) or, just plug it back onto the wire and let it dangle somewhere.
Old Nov 19, 2001 | 10:20 AM
86-red_dawg's Avatar
i never hooked the sensor up to my open air filter, and i never got the ses light - i think your problem is elsewhere - i just capped the port with a plug, and all is good
Old Nov 20, 2001 | 09:08 AM
korbin's Avatar
i've already changed it.... the sensor, ok put it in the air filter..(doesn't make a whole lot of sense to me but okay...) but as for the vacuum hose, are we taking bout the one going to the exhaust manifold? cuz the manifolds are coming off.... i have a hose coming from somewhere in the back left of the engine and it lets out smoke...or i dunno what but it dirties up my air filter so it obviously needs to be taken off or plugged...WHAT DO I DO WITH IT?
Ghettobird52
Jul 5, 2024 11:18 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
wruiz
Aug 13, 2015 09:07 PM
