Breaking in motor..... NEED HELP!!!
Old Oct 27, 2005 | 05:15 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
ok so im breaking in my cam/heads/intake swap 350...
my car wont run more than 5 mins or less 4 overheating..... and i got a substance leak.....
i fear it may be *gasp* oil coming from the rear intake seal..... its falling on the header collector and burning.... how can i tell for sure wat it is....
and whats up with my oevrheating so fast?!?!? timing!?!?
Old Oct 27, 2005 | 05:16 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
im about 15mins of running on the engine now FYI.... but i have to run it and stop when it starts to get too hot....
Old Oct 27, 2005 | 05:34 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
see my post in the cooling area
https://www.thirdgen.org/techbb2/sho...hreadid=326935
I had same problem
Old Oct 27, 2005 | 08:55 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
thanks... ive narrowed my problems down to a punch list..
valve cover gaskets shot
need a 2ndary coolong fan
had not enuff coolant.
Old Oct 28, 2005 | 01:03 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
maybe a stuck thermostat?
Old Oct 29, 2005 | 03:31 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
checked it.... low coolant... but im still suspicious of several things... i gotta small leak outa one of the core plugs but not bad enuff to make a difference.... just a small weep...
i replace the thermo with a new one...and coolant and it runns cooler but still bad.. im thinkn new radiator
Old Oct 29, 2005 | 10:17 PM
sellmanb's Avatar
Car: '86 Berlinetta
see: bigger radiator
During the cam break-in you can expect it to get hot enough to make your coating flake off on the headers, so it will run hotter than usual.
Make sure you have the correct 50/50 mix of water and ethelyne glycol (antifreeze) and that it's full.
Also make sure that your radiator cap is working properly. 9/10 they dont hold their advertised poundage rating right out of the box, none the less if it's your original cap.
Make sure your belt isnt slipping around the water pump as well.
You can hot wire your fans to be running at all times. I suggest this for you.
Lots of people here believe that starting and stopping several times during a cam break-in is going to dramatically hurt your chances of it breaking in properly since in the first 5 minute interval you washed off all the cam lube with engine oil. After that the motor was stopped for an excessive amount of time to let it cool down. Then it has to be started again with no form of lubrication for a couple seconds while oil gets back to it's flinging nature .
There are also lots of people here that believe that it doesnt make enough difference to matter and that if the cam doesnt break-in properly that it wasnt going to anyways, and isnt neccessarily the fault of being turned off and restarted after a while.
Just food for thought
Old Oct 29, 2005 | 11:42 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Thanks.... lots of good food....
1. Getting a griffin 2 1" core alum radiator for my b-day
2. Alright for running warmer during break-in.. but when it wants to break into head ruining temps i tend to shut it off to save my $1500 heads
3. still runs hot right now... read 1
4. according to the water wetter bottle its supposed to cool better minus the glycol but im not seeing anything show stopping so tomorow im pickin some 50/50 up
5. fan.. only one 16" electric is wired to a switch which i usually have runnning anyhows.... it was hot wired to ign on but i had a problem withthe car recieving feed back and dieseling so i took it off that wire
Old Oct 31, 2005 | 09:25 AM
Car: 88 Camaro
Engine: 310 LG4
same problem wirth my cam, i started and stoped several times and my cam is fine. try to find my "310 saga" thread for more info.
Old Oct 31, 2005 | 09:37 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
car is broken in all fine now... lol i still have a stupid problem with my carb... i dont know if its timing or the carb..
and i have a no charge situation now... grrr
Old Nov 1, 2005 | 09:35 AM
Car: 88 Camaro
Engine: 310 LG4
again see my post lol! Do you have ythe 3 wire alt? I do, my diagram had the wiring backwards! So my motor wouldnt charge the batt, but wouldnt turn the car off either, it just kept running lmfao! I reversed the wires and it works great.
Old Nov 1, 2005 | 07:30 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
lol i dont have that problem.... im thinkin im not getting any juice to the alt. to excite the field winding.... il check it tomorow and let you know
thanks very much for all the help
Old Nov 2, 2005 | 07:28 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
If you have A/C see if the condenser is blocking too much air to the radiator. I had many cooling problems through 2 motors. When I took the condenser out and noticed that all the fins were bent it solved all my problems.
Old Nov 2, 2005 | 08:25 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
yea i know my condensor is all messed up... thanks to several bolts breaking in the previous motor i had to drill and stuff so many fins are bent..
this motor doesnt pull enuff vacuum to use the A/C anyhows so im getting rid of what i can... although im gunna get a new radiator nehows
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
