Engine misfire/backfire??!
Old Oct 29, 2005 | 03:14 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
ok at low idle, when i goose it the carb gives a lil pop... not like a complete backfire..
it bogs a lil then pop and i gotta feather the pedal to keep her goin... thats only from a stand till though....
the motor is just swapped in '75 350.. with alum heads,intake, big cam( i dont have any power assit brakes at idle )
i set my timing at about 5* advance at base...
i have a lunati cam and i set it to 0* advance as far as i can tell....
is there any way to double check my valve timing with the engine in the car??
also i have an overheating issue. see my thread in cooling....plz
Old Oct 29, 2005 | 05:51 PM
Vader's Avatar
Yes. With a piston stop, degree wheel, and dial indicator, you can plot the valve timing with the engine installed in the vehicle. You'll likely have to pull the harmonic balancer to do it, but it's a common thing to do.
Attached Thumbnails Engine misfire/backfire??!-degreewheel.jpg
Old Oct 29, 2005 | 05:54 PM
Vader's Avatar
And despite your pleadings, I'm NOT going to kiss you - Not in Florida, Georgia, the Carolinas, Virginias, or anywhere else, for that matter...
Old Oct 29, 2005 | 09:50 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Engine misfire/backfire??!
Originally posted by Saigon_Bob
ok at low idle, when i goose it the carb gives a lil pop... not like a complete backfire.. big cam( i dont have any power assit brakes at idle )
( 290*,297* adv duration cam.. )
This isn't a street cam. You will need a high-stall converter for it. Set the idle at 1000-1100 rpm. Change the distributor vacuum advance to work with the lower vacuum.
Old Oct 30, 2005 | 12:00 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Re: Re: Engine misfire/backfire??!
yea for real... holley sells this cam in a kit with heads and intake...
its pretty nasty lope... real nice sounding but i know i gotta change some things around...
as for the vacuum advance... how should i set that up for less vacuum?? weaker spring?
higher stall convert is comming with the new trans... my next money venture
Old Oct 30, 2005 | 12:06 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
yea.... gotta get me one of those... im gunna get the one that comes with the instructional video too.... worth the money i suppose
Old Oct 30, 2005 | 12:11 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
on a side note... my timing gear is set up to allow 4* retard, 4*advance, and straight up timing.... im pretty sure my cam is ground with a lil advance already so i installed at 0*...
what are the benefits of advancing and retarding valve timing
Old Oct 30, 2005 | 12:29 AM
Engine: 350 4BBL
Re: Re: Re: Engine misfire/backfire??!
Make sure your Probillet doesn't already have this and add it to your shopping list:
(from Summit website)
CRN-99600-1
Distributor Advance, Vacuum, Adjustable, GM, HEI, Kit
These Crane adjustable vacuum advance kits let you tailor your ignition to the advance you want. The adjustability provided by these kits permits you to run the maximum amount of ignition advance throughout the rpm range, without incurring detonation. Once they're installed, you can quickly compensate for changes in fuel quality and altitude. Each kit comes with a vacuum diaphragm, an Allen wrench, advance weight springs, and instructions.
Advancing & retarding the cam timing will move the torque peak around, but for most of us guys it's how you keep the piston from hitting a valve with a long duration, high-lift cam.
Old Oct 30, 2005 | 08:58 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Re: Re: Re: Re: Engine misfire/backfire??!
CRN-99600-1
well i dont have any valve clearance problems right now so im pretty sure im straight...
im still stumped on the engine poppin... kinda pissin me off...
i need a new starter... also my new alternator and battery( i had to buy them) arent chargin... im suspecting the starter isnt letting the alt charge the batt... could i be wrong?
Old Oct 30, 2005 | 09:39 PM
Engine: 350 4BBL
Re: Re: Re: Re: Re: Engine misfire/backfire??!
Only way the starter could keep the alternator from charging the battery is if it never cut off after the engine fired. Check your wires.
Old Oct 31, 2005 | 09:44 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Re: Re: Re: Re: Re: Re: Engine misfire/backfire??!
alright... ill check em again...
i had the wire that is black then splits to two reds burn from the 305 and i replaced it but i need to know wat wires are supposed to be on the starter...
like what ones go on the lil post and what ones go on the larger post
Old Nov 1, 2005 | 06:19 AM
Engine: 350 4BBL
The alternator is pretty simple. The heavy positive wire that comes from comes off the alternator goes to the positive post on the battery. The plug-in on the alternator should have one "hot-always" wire and one that is hot when the key is on.
Old Nov 1, 2005 | 07:36 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
ok well ill check that tomorow.... im not sure how the starter is wired but its fishy... ill let you know
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
