quick question on valve seals
Old Nov 22, 2001 | 09:41 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The guy at NAPA insisted that the seals he gave me were correct exhuast seals, but they look very similar to the intake seals. I remeber reading somewhere that those seals that are pressed onto the head are good for intake but bad for exhaust. Is it ok to use these seals on the exhuast, or should i stick with the conventional umbrella seals? Thanks in advance.
Old Nov 23, 2001 | 02:08 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If the head are machined for positive seals, I use them on both.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 23, 2001 | 06:48 AM
ede's Avatar
ede
i use both too, o ring and the umbrella type positive seals. i know the fel pro ones i buy that fit on the valve guide work for both intake and exhaust. did they come in a pack of 16?
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 23, 2001 | 12:13 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Sorry, I was not very clear about that. I got positive type seals not umbrella or o-rings for the exhuast seals for the exhuast. Can you use these on the exhuast end? My brother told me when he rebuilt his ends that you guys said not to use positive seals on the exhuast, and stick to umbrellas and o-rings. Why can't you use postive type seals on the exhuast?
Testing the new sig
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Edelbrock Headers, Rebuilt B&M 700R-4 Tranny, Higher Stall Torque Converter, Airfoil, 3.4 w\posi, K&N's, Ported & Polished Plenum
-- Blue LED Bakelite Dash & Climate Control
- I am just some 17 Year old spending every dollar I make on my car.
[This message has been edited by 89 Iroc Z (edited November 23, 2001).]
Old Nov 23, 2001 | 03:43 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
As I said above, I use them on both if the head is machined for them. (in and ex.) never had a problem.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Nov 23, 2001 | 04:10 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
note to self: do not reply to post right after waking up, apply coffee first.
Old Nov 23, 2001 | 05:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I use the positive seals on both whenever possible. AFAIK there's no reason not to. The umbrellas are a distant second, a poors substitute at best. I don't bother with the O-rings unless that's the only thing I have, in which case I try to delay assembling the heads until I have something that actually works.
ICON Motorsports
Old Nov 23, 2001 | 05:54 PM
Guest
Guest
Posts: n/a
I would use them on both and not worry about it. The story on not using them on the exhaust side goes like this:
Using them on the exhaust side, which sees exhaust pressure going up the valve stem rather than the vacuum pulling down the stem on the intake side can cause problems. Due the the exhaust pressure there is more of a tendency for oil to be removed from the guide and stem, so you dont want to restrict oil flow on the exhaust side as that will promote valve guide and stem wear. Using normal seals doesnt restrict the oil flow and keeps more oil on the stem and guide and will prevent excess wear.
Thats the story anyway. SBF's dont have a wear problem and all the mid-80's up use the positive seals on both. Its essentially the same setup otherwise, I think someone had a bad experience and went paranoid.
crazynights
Aug 21, 2015 06:53 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
