hyd roller lifter question
Old Nov 1, 2005 | 05:50 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ok i toasted a lifter, long story, anyways i bought a new one at work and with it in the engine, i noticed i can push on the pushrod and feel it plunge a little and of coarse come back up. is this the normal hyd part they speak of? cuz none of my other lifters i could push down on. but when i looked at the lifters, the plunger part was at the top and not sunk down.
Old Nov 1, 2005 | 06:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If there's no oil in it, you'll be able to compress it.
Old Nov 1, 2005 | 08:10 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
oh ok thanks, so when it fires up it will become non compessable?
Old Nov 1, 2005 | 08:22 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: hyd roller lifter question
Originally posted by TraviZ
... the plunger part was at the top and not sunk down.
Que?
Old Nov 1, 2005 | 08:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
As soon as it gets filled with oil it should be hard to compress. Some people pump their lifters up in oil before installation.
Old Nov 1, 2005 | 09:32 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Take the lifter out and soak it in oil for a while to get some oil in it. Put some assembly lube on the roller and where the pushrod goes. I don't know if it is necessarily required with roller parts, but I do it on all of mine anyways. Can't hurt any.
Old Nov 2, 2005 | 12:42 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yes, it can hurt.
The assembly lube is thicker than oil and can block the holes in pushrods. If oil can't get through then that valve spring may not get enough oil to lube it and keep it cool.
Also, the roller on the lifter needs a little friction to roll against. If the lube keeps it from rolling it could develope a flat spot.
Old Nov 2, 2005 | 12:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There will be more than enough oil pressure to flush out any assembly lube in the pushrod. Assembly lube is also soluble in oil, after the few minutes of operation any assembly lube will be dissolved into the oil anyway. I can't see how it could keep the roller from turning on the lobe either.
Old Nov 4, 2005 | 11:24 AM
AJ_92RS's Avatar
Then use it that way and increase your chances of screwing something up. Doesn't matter to me either way.
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
