Best HomeMade Way To Remove Crank Pulley
Old Nov 3, 2005 | 10:08 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well id rather not bring my car to a shop to get them to remove the pulley, id like to do it myself.
how do i remove my crank pulley, there are 3 bolts around the 5/8" bolt in the middle? do i need to remove them all?
thanks in advance
Old Nov 3, 2005 | 10:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yes.
Old Nov 3, 2005 | 10:42 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Just the outer 3 to remove the pulley, the center one is what holds the dampner to the crank. If you want to remove the whole dampner you will need to either purchase a puller or rent one.
Old Nov 3, 2005 | 11:18 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
not the dampner, thats the balancer right? i just wanna take off the pulley so i can put a new one on
Old Nov 3, 2005 | 11:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Same thing.
Old Nov 4, 2005 | 04:05 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
yes,
Same for me:
I tried a lot of home made "ideas". Finally I bought a chinese puller "made in Taiwan" for local CH$ 15,000.00 = US$ 27.00
Denis V.
Old Nov 5, 2005 | 08:51 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The best homemade method I can think of would be.
A. Buy a $20 puller or B. Find a parts store with a loner tool program.
Old Nov 5, 2005 | 10:32 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i guess if you've actually done it, the 3 bolts were nothing to take off, i just wrapped a belt around the pulley and yanked on it, and my brother untightened the bolts, but the pulley wouldnt come off, then i came up and read on here, i need to take out the center bolt, i hope its as easy to take off as the other 3.
what about the harmonic balancer, i know the crank pulley will just slide off, but will the harmonic balancer to? i want to install a polished aluminum timing cover also, so i need to take that off.
any ideas, does it know where to sit when i put it back on, as in it only goes on one way? or just mark where the white line is, and make sure its in the exact same spot?
Old Nov 6, 2005 | 02:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The dampener is pressed on to the crank snout. You'll need a puller to take it off, and an installer to put it back on without damaging the threads. It's keyed so you don't have to worry about putting it on wrong at least.
You'll also need to drop the front of the oil pan or modify your cover to get it on.
Old Nov 6, 2005 | 02:58 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i figured that, i probably wont get into that, just to change the timing cover thanks alot, you always seem to be the one to respond in my threads
Old Nov 6, 2005 | 10:43 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
If you want to change only the main pulley, you need to remove the outer three bolts AND the center bolt. Then the pulley will simply fall off.
If you want the change the timing cover also, then you will need to remove the harmonic balancer and the water pump.
For the harmonic balancer, I go to AutoZone and borrow a kit which contains the correct adapters for doing that job. Once, you have taken it have, you will need to press it back on.
In removing the water pump, you should drain the coolant from the radiator.
So, in all, this is a bit of work, but very doable. Its a good project. One thing tnat I have learned over the years is that if you are going to do your own work, get good tools, and the right tools.
Old Nov 6, 2005 | 10:56 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
oh yea i just put on new heads/intake/carb/rockers/pushrods, but got new pulleys and water pump, thought i could put anew timing cover, but i doubt ill do tht right now
rthanks
anesthes
Mar 10, 2016 10:35 PM
mddaniel
Sep 8, 2015 05:16 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
3rdgenparts
Aug 8, 2015 07:09 PM
