new spark plug wires
Old Nov 4, 2005 | 10:35 PM
19Irocz86's Avatar
Car: 1986 Iroc z z28
Engine: 305 tpi
well my car starts fine and runs pretty decent but when first start and idleing 4 about a min and you give it gas it wants to die, it bogs almost dead for about 2 sec then it rev's up, im thinking its the fuel injectors since there the stock ones that come in it back in 86, but i am gonna try 2 upgrade my spark wires first, and thats my other question what whould be the best ones to buy 4 a stock 305 TPI with everything stock on it??
thanks
Old Nov 5, 2005 | 01:22 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It's not uncommon for it to do that while in open loop mode. The O2 sensor is bypassed during this time and the A/F mixture is set to run a little rich also.
When you blip the throttle you're changing the A/F ratio for a nanosecond (or slightly longer). No different than doing it to an engine with a carb.
Once the engine reaches operating temp. and/or after a set amount of "warm up" time, the O2 sensor starts working and all should be fine. If not, THEN you have a problem.
Old Nov 5, 2005 | 06:35 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Old Nov 5, 2005 | 09:48 AM
19Irocz86's Avatar
Engine: 305 tpi
thanks 4 the info
but i think it is still time to change the wires
im new to this and I have 2 clue which ones 2 get??
whats the best wires 4 my car
thanks AJ_92RS that takes a load off but one day I will replace the fuel injectors which looks like a JOB aint the stock ones 19 pounds injectors?? should I upgrade 2 bigger ones or just keep it stock??
Old Nov 5, 2005 | 12:44 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
if I grab my sparkplug wires near the boot and they zap me is it time to get new spark plug wires?
Old Nov 5, 2005 | 05:59 PM
19Irocz86's Avatar
Engine: 305 tpi
whats the best wires 4 my car?
Old Nov 5, 2005 | 07:29 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ones that work.
your not going to see much difference between plug wires
Old Nov 5, 2005 | 07:34 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Get a cut to fit set of Moroso Blue Max wires. The cut to fits are guaranteed to fit how you want. I like their boots better than the MSD (more resistant to temperature and they seat on the plug better) and the ends are easier to assemble than the Taylors. If you want to you can get the Made For You wire looms for the centerbolt valve covers. If you decied to get them too, you can get the whole package from Thunder Racing.
Old Nov 5, 2005 | 08:09 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Fuel injectors arent too bad to do. Stick with stock, you dont need larger, and if you did get larger, first assuming youre an MAF car (not sure on that), you'd need to have the MAF recalibrated to that injector size. Second, you'd probably end up being rich and need an AFPR, or have a chip burned, to dial the fuel back down....and sizing down injectors never seems to work quite as good as just having the proper size in there in the first place.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bryan F
Aug 18, 2015 02:28 PM
