Egr Q
Old Nov 6, 2005 | 03:10 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Egr Q
Any idea what kind of an impact getting rid of EGR will have on highway mileage? Will it have any effect at all?
Old Nov 6, 2005 | 03:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
1 MPG is the rule of thumb i've heard.
however it keeps the engine running cleaner I think, and it doesn't rob any power whatsoever...
Why remove it? broken?
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I didn't see a change when I took mine out. Mine was stuck open so I just cut a peice of metal and blocked it off. Haven't had any problems so far- it's been about 2 years.
Old Nov 6, 2005 | 03:14 PM
MattODoom's Avatar
Car: '88 G T/A
Switching to Stealth Ram.
Old Nov 6, 2005 | 03:19 PM
85cmroz28's Avatar
Engine: L69
Yeah, you're good. Don't worry about EGR unless you have emissions testing in your state. If you do have emissions testing, you will need EGR.
Old Nov 6, 2005 | 03:20 PM
MattODoom's Avatar
Car: '88 G T/A
Its michigan, home of the automobile, we don't care about smog here!
Old Nov 6, 2005 | 04:56 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
All the EGR does is re-burn some of the exhaust gasses to lower the NOx levels at the tail pipe. If you don't have to test then don't worry about it. And unless the car has NOx sensers before and aft the converter, the ecm should not even throw a code as long as you bump up the fuel psi a tad. If your car does have the two NOx sensers, then replace them with sims after you remove the EGR valve.
I see you are going to use the stealth ram? You going to use the factory ECM or an aftermarket?
Old Nov 6, 2005 | 05:24 PM
MattODoom's Avatar
Car: '88 G T/A
Ill be using the factory '88 MAF ECM, maybe repinning to MAP and converting the BIN. Don't know yet.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
