Is the 700r4 casing identical to the 4l60e casing?
Old Nov 16, 2001 | 11:22 AM
Brandog87GTA's Avatar
I bought a 4l60e that had a cracked case and I am wondering if their case is the same. I know the 4l60e has the electronic valve body, but the case may be identical. I have a 700r4 case and was gonna swap everything into it. Is it possible?( to sell, not use)
Bright red 87 GTA with I have stock 3.27 gears,2200 stall,B&M shift kit, TRW forged 9.75:1 pistons,comp cams pushrods, edelbrock valvesprings, 462 camel hump heads with 2.02in/1.60ex redrilled for angled plugs, 3 angle valve job, ported and polished, performer RPM intake, mallory fp regulator, edelbrock 750 CFM carb, hei ignition(new) with 40,000 volt coil,No cat, flowmaster 1 chamber mufflers, hedman 1 5/8 full length headers, edelbrock cam with 488/501
Best Run 1/8 mile 8.62 at 84MPH on street tires, Consistantly run 8.8. 60 foot times 2.3
Old Nov 16, 2001 | 11:27 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yes. Except the tail.
AJ
Old Nov 16, 2001 | 11:33 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Actually, the internals for the GM SRTA (Remanufactured 700R4) uses the newer internals from the 4L60E and just puts them in an older 700R4 case with the manual valving. Sounds like you want to do the same thing that GM does.
Old Nov 16, 2001 | 05:41 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
no, the case isn't the same, but the internals to make it go are with the exception of the valve body and input shaft.
Old Nov 16, 2001 | 07:36 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
What year 4L60e are we talking about? The case on an "e" model is different than that of the 4L60(700). The internal components are similar and you may be able to swap parts. But your problem is a broken case and you will have to find an "e" model case. I know the pump is interchangeable up to a certain year, if you need to know the years that will work, I can get back to you.
By the way, one way to find the year is to look at the shift servo cover on the side of the transmission. It is stamped with the year the tranny was made. You just have to hope no one changed the cover.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 355CI, 2bolt, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Best Times:60ft 2.26 1/8th 9.68 @ 73.63 Soon: 3.73 or 3.42, Gears, Hoosier Q/T
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=7480
Old Nov 20, 2001 | 02:04 PM
Well, its out of a 95 trans am. So the tranny should be a 95. So you are saying the internals cannot be swapped? The only difference I noticed was 2-3 clutch packs have 9 sets instead of 5. THe appear identical internally to the 700r4.What is different about the case??? The holes drilled for the valve body?
Old Nov 20, 2001 | 02:05 PM
Okay guys, I am confused. I am getting mixed messages, some say the case is the same, some say it isnt.
Old Nov 20, 2001 | 02:16 PM
BTW, can the internals of a 700r4 be swapped completely in a 4l60E??? I dont see why not, other than the fact that the 700r4 setup will make a little weaker. The input housing is the same as on a 700r4(Called GM and matched part numbers).
Old Nov 20, 2001 | 02:19 PM
a73camaro's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Brandog87GTA:
</font>
You gotta mean the 3-4 clutch pack.
Second gear is done with a band and the forward clutch pack.
Old Nov 20, 2001 | 04:03 PM
Yeah, 3-4th. sorry
Old Nov 26, 2001 | 10:26 AM
Come on, someone has to know....
Old Nov 27, 2001 | 12:33 AM
AJ_92RS's Avatar
You're just on the wrong board. Go to the Trans.. & Drivetrain board and page transfixleo. He'll be able to tel ya fer sure.
AJ
Old Nov 27, 2001 | 05:58 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You can put the 4L60-E internals into the 700's case, but it won't be a 4L60-E. The case IS different, because of the valvebody. All new passages had to be cast to accomidate, not to mention there is an extra hole for the large electrical plug.
I doubt highly that you can use the 4L60-E's pump though, but most of your hard parts will swap over.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
loud91rs
Oct 5, 2015 10:05 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
