Differences in original ZZ4 and newer ZZ4 rotating assemblies?
Old Nov 26, 2001 | 08:38 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
What are the differences? I've heard the only difference is the new ZZ4 has a forged crank while the old ZZ4 had the nodular iron crank. Are the rods and pistons still the same (powdered metal rods and hypereutectic pistons)? What about the old ZZ3 motor?
Thanks,
Stephen
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Nov 26, 2001 | 09:51 PM
89BlwnRs's Avatar
To my knowledge, the ZZ4 always had a forged crank. The ZZZ-ZZ3 all had forged cranks. However the crank in the current ZZ4 is balanced to connecting rods (PN 10108688) and piston (PN 10159436).
Hope this helps a little,
Jason
Old Nov 26, 2001 | 10:14 PM
poncho9789's Avatar
yes the newer zz-4 engines have a forged steel crank in them but other than that I don't think they have changed anything.
Old Nov 27, 2001 | 09:52 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ZZ3 did not have hypereutectic pistons or PM rods. The drain plug was SAE, went to metric with the ZZ4.
Block, cam, heads, intake, etc., all the same.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
mhatfield 14
Oct 24, 2015 07:48 AM
bamaboy0323
Sep 3, 2015 06:07 AM
