vortec heads
Old Nov 12, 2005 | 08:26 PM
vinceanity92's Avatar
Car: 1992 rs
Engine: 305 tbi
vortec heads
if i were to run L31's would i have to go with reverse flow cooling, i thought all vortec's u had to have a bassakwards water pump, do they make a electric reverse flow water pump?
Old Nov 12, 2005 | 08:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
that's only on LT/LS motors I think. Look up what ME Leigh did to use LT heads on his 305...
Old Nov 13, 2005 | 07:50 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Only LT'x' engines had reverse flow cooling (as well as the L99, aka baby LT1).
They're also known as Gen II small blocks.
What you may be confusing is reverse flow and reverse rotation.
A lot of engines with a serp. belt setup used reverse rotation water pumps because the pulley rotated "backwards" compared to older "V" belt systems.
The fluid still flows through the engine the same direction as any other Gen I block, but the impeller inside the water pump just spins the otherway. Therefore it has different angled fins.
Old Nov 13, 2005 | 09:36 AM
Car: 1992 rs
Engine: 305 tbi
so i can use a regular water pump or do i need to get one off of a 96-97 pickup as these heads were
Old Nov 13, 2005 | 09:59 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Use your regular '92 one.
Old Nov 13, 2005 | 01:16 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
nothing magical or fancy about those heads except that they need a specific intake manifold. Besides that everything else is "standard" and will work with "standard" stuff...
Old Nov 13, 2005 | 08:38 PM
Car: 1992 rs
Engine: 305 tbi
hey thanx for the info on the heads appriciate it
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
