Oil Overfilled ~1/2 Qt...Bad?
Old Nov 12, 2005 | 09:12 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I changed my oil today with 10W30 full synth and when all was said & done (new filter, oil, filler cap on and engine started for ~30 seconds) the 5 gallon oil jug was empty and the dipstick showed about 1/4" above MAX. The engine has 170,000 miles and doesn't leak/burn oil. Cold pressure is ~50 PSI @ highway speeds. I'm thinking this is all OK, but decided to be **** about it. Should I drain out the extra 1/2 quart or should it be cool as is?
Old Nov 12, 2005 | 09:14 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I think you'll be fine, but extra oil WILL make the oil run hotter and you'll lose a little bit of pressure, especially at WOT.
Old Nov 13, 2005 | 11:34 AM
rjmcgee's Avatar
Re: Oil Overfilled ~1/2 Qt...Bad?
You mean quarts right?
Cause 5 gallons would be a little on the full side.
Old Nov 13, 2005 | 11:49 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Ummmm...yep! I guess it would've felt a little heavy if it were five gallons.
Old Nov 13, 2005 | 02:09 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
how would the pressure run lower and make the oil hotter if it was a little full
Old Nov 13, 2005 | 03:37 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Our cars require 5 quarts correct? When I put 5 in, it also reads a little high. I also warm up the engine before draining.
Old Nov 13, 2005 | 04:29 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I've had good luck with 4.6 qts with the L34631 filter (purolator number, but that size of filter).. 4.6-4.7 puts it right at the full mark once the engine has been run.
Old Nov 14, 2005 | 01:14 AM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
the oil filter will hold ~.25-.5 qt on its own assuming you replaced it. I wouldnt worry about it unless you went 1-1.5qt+ over.
Odd enough, my 2.8L hold 5.5qts
Old Nov 14, 2005 | 01:54 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I think at 5 gallons it would be coming back out the valvecovers
I usually throw in a full 5 quarts, my engines pretty old and beat so it just gives me longer before i have to check or add oil
Old Nov 14, 2005 | 06:47 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
but hey the 5 gallons might give your old motor some more oil pressure
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
romcjr
Sep 17, 2015 05:18 PM
