062 vortecs need work,what can i do?
Old Nov 13, 2005 | 10:22 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
It's me again with another pop quiz guys.
I was going to get some 081 heads for my L03 but a friend here in town is going to sell me some 062 vortecs and some 1.6 roller tip comp rockers for $175.The only problem with the heads is that there appears to be some galling on the exhaust valves.could a machine shop repair the exhaust valve guides?are they actually repairable?There are no other defects in the heads besides this.The galling isn't bad but can be seen on the valve stems.Thanx for the help in advance.
Old Nov 14, 2005 | 08:00 AM
anybody?
Old Nov 14, 2005 | 07:03 PM
31 views and no responses come guys i know somebody here knows.
Old Nov 14, 2005 | 07:36 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
The guides are easy to repair with a bronze thin wall liner, and OEM repl valves are pretty cheap too.
It seems like a good excuse to get a good HP valve job done and buy some new SS exh valves while you're at it.
But if you're really hard up, you could get by with the old used stuff too. Just buff the marks out with some 400 emery paper. They'd be a bit loose, but it wouldn't do any harm as long the seals are new.
They just wouldn't last as long as if you bought new parts.
Old Nov 14, 2005 | 10:43 PM
well the heads are bare,what kind of springs and what are the best valves that i can get?I want to get atleast a .550 lift max out of these.
Old Nov 15, 2005 | 08:40 AM
anybody else?
Old Nov 15, 2005 | 11:41 AM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
If the valve guides are loose, as in you can wiggle the valve, no seals will be able to seal them. (Lesson learned on LB9) I recommend doing everything right the first time.
Old Nov 15, 2005 | 12:33 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If the guides are too loose you will eventually hammer the valve seat out of round & that won't seal. Any competent machine shop can install new guides. OEM & aftermarket valves are readily available. You should match the springs to the cam you are going to use. The cam manufacturer can recomend this.
Old Nov 17, 2005 | 07:57 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Galling on the top of the guide or on the bottom? Was the machining done previously to accept the higher lift? Were the 1.6 rockers used on the vortecs previously? What about the spring seats? I would also have screw in studs put in to run that amount of lift if it hasn't already been done.
Old Nov 17, 2005 | 08:36 AM
the galling is on the stems themselves ,and yes 1.6 rockers were used before. the 1.6`s are the ones i`m purchessing as well.as far as everything else they`re bone stock.I plan on getting screw in studs as well.
Old Nov 18, 2005 | 07:15 PM
ttt
Old Nov 19, 2005 | 05:45 PM
crewguy's Avatar
This is what I have in the heads that I had prepared for a motor rebuild in progress right now:
machine shop labor:
$150-3 angle valve job (includes cutting for larger valves)
$100-install screw-in studs
$35-hot tank and mag heads
$50 set spring height
labor total $335
I bought new S/S 2.02,1.60 valves, screw-in studs, and CompCams springs(inc. retainers and locks). I lost some of the reciepts but $220 is a ballpark figure.
Total is $555.00 for parts and labor. Now add the $170 that I paid for narrow-body, full roller rockers and the total comes to $725.
Now I add the price for the bare heads, $150, and I have a grand total of $875 invested in these unported Vortec heads.
Old Nov 19, 2005 | 06:35 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I have a set assembled with ss valves, 5 angle valve job, guides milled, aluminum valve covers, rockers, screw in studs, guideplates and performer RPM intake for $925. Brand new. Heads and springs good to .550".
Old Nov 19, 2005 | 07:26 PM
crewguy's Avatar
Originally posted by Dialed_In
I have a set assembled with ss valves, aluminum valve covers, rockers and intake for $925. Brand new.
This is a deal if the heads are fresh! I paid $160 for an airgap intake. Someone should jump on this deal NOW!
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
jharrison5
Aug 19, 2015 05:53 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
