Car stalls need help
Old Nov 30, 2001 | 05:50 PM
Ratchet's Avatar
86 2.8 camaro. When you come to a stop the idle goes down and keeps right on going down until the engine quits. When you start it up it idles at 500 rpm used to idle at 750. Sometimes stalls when you turn a corner also
checked the 02 sensor now I don't know what to check HELP this is really bugging me what is causing this?
White bone stock 87 RS
Old Nov 30, 2001 | 06:37 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Your timing,Idle Air Control valve located on the throttle body gun,Throttle Position Sensor located on the throttle body,or a bad fuel pump.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
