ignition module woes..
Old Nov 29, 2001 | 11:54 PM
age's Avatar
age
Car: 1992 Z28 1LE
Ok, so a couple of nights ago, my 92 Z28 went through it's 3rd ignition module in about 2+years. So now, I'm on my fourth.
Has anyone else had any problems with ignition modules? Any tips/hints as to how or why this is happening to me?
I have the MSD cap/rotor/coil/6AL/wires.
The distributor is probably still the original one on there, so maybe the pickup coil is faulty? I can't think of anything else..
thanks!
Old Nov 30, 2001 | 01:18 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
It sounds like you have a short in your ignition system somewhere and that is ruining your modules. but make sure you test to see if the modules are actually bad. I did the same thing -- switching modules until I found that they werent actually going bad and that I was just disturbing the short every time I changed it. now I have 3 working modules.
(but I still really havent found all my electrical shorts!)
good luck!
Old Nov 30, 2001 | 04:43 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I check to see if I connected the output of the HEI module to the right input wire on the MSD6al. If connected wrong the 6AL could be drawing too much current through your
HEI module, causing early failure.
Old Nov 30, 2001 | 07:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The heat sink grease is also important. Are you using it?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 30, 2001 | 08:31 PM
age's Avatar
age
Car: 1992 Z28 1LE
The 6AL is hooked up properly. I bought the MSD install kit that's dummy proof.
I do try to use every bit of the white grease that comes with it. Unless if the MSD is causing more stress/heat to the ignition module, because I heard that with an aftermarket ignition, things start to run a lot hotter... if so, should I just apply extra dielectric grease?
also, how would I check for a short? I guess I should get those modules tested out first..
thanks guys
Old Nov 30, 2001 | 08:58 PM
Guest
Guest
Posts: n/a
Just inspect the wiring to make sure its not grounding to metal, except the ground of course. On older styles a bad ground to the coil would fry modules on a regular basis. I'd be checking that out.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
