Can I Run My Engine, With Power Steering Pump Off?
Old Nov 15, 2005 | 09:47 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
just like the topic says, i took off my power steering pump to get the pulley off and maybe clean it up and install the new march pulley i got for it.
can i just plug off the hoses that were going into it? im not going to be driving it, but it will be a couple weeks before i actually end up putting it back on.
and i got a new pushrod checker so i wanna test that out, and get new pushrods and put them in, and want to be able to start up the engine if i dont have the power steering pump back on by then.
Old Nov 15, 2005 | 10:07 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
As long as the pump doesn't spin you'll be fine. Otherwise get your rags ready for spraying power steering fluid.
Old Nov 15, 2005 | 10:13 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
what do you mean as long as the pump doesnt spin? the pump is out of the car, right here beside me almost. as the rest of the motor being polished aluminum id like to clean this up a bit.
i was just wondering if there was a way power steering fluid would come out of the lines that are still attached to the car that i unplugged from the power steering pump.
p.s., the pump is OUT of the car no pump in car.
Old Nov 15, 2005 | 10:15 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
if you start moving the steering wheel around you might end up with a bit of a mess on the floor.
Their wont be a problem running the engine without the power steering pump. So long as the other acc belts are still on to run the water pump.
Old Nov 15, 2005 | 10:16 PM
Car: 86 T/A
Engine: HSR 355
Oh ok, wow I totally missed that. Yeah, you should be fine just keep the lines from getting dirt in them. I'd get a second opinion to be sure but I don't recall any vaccum lines running there.
Old Nov 15, 2005 | 10:38 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
hmm just a rubber hose which goes into a steel line, and a steel like that screws into the back. i have a belt for the water pump alternator and crank shaft pulley. the other belt(power steering, water pump, and crankshaft) is not installed right now.
if its a big deal i will just wait until i install it again.
Old Nov 15, 2005 | 10:41 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Not a big deal at all, like i said as long as you have the other belt on to run the water pump youll be fine. you can actually drive it around like that but you had better have strong arms. I drove my car around for a couple weeks with no pump when mine bit the dust.
And yes, be sure to cap off the ports in the steering box, theirs nothing more that the pump hates than a bunch of dirt chewing it inerds up!
Old Nov 15, 2005 | 10:50 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok ill block off both lines
my power steering belt broke off one time and i had to drive around for 3 days like that since i had to order one.
thanks guys for your help
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
