my freind's LG4 just blew up
He offered me $300 for my old L03. Can he just throw this in place of the LG4 and have no problem? He is gonna keep all of the old stuff just my L03 longblock.
thanks
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis strut tower brace
"There is no way you have a 350 in that car. They are made to have 305's and a 350 wouldnt fit"
-local parts store genius-
thanks
*1989 RS
*355 CID
Transmission: 4L80E/4L80E
Depends upon the year of his car/engine. Yours had a one-piece rear main seal, meaning a different flexplate/flywheel than a two-piece rear main seal. If his car is '86-newer, no problem. If '85-older, he'll have to get a different flexplate/flywheel.
Otherwise, it should bolt in with his intake, distributor, etc.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Well, forgot one other item.
If his current engine is '86-older, the intake manifold will have the center two intake bolts on each side at a different angle than the heads on your engine. He can elongate the manifold bolt holes and make it work, or get a manifold with the different bolt angle holes for it.
Car: 1989 C4
Axle/Gears: 307
You also might want to peek at the fuel pump boss on your old engine and see if its drilled for a mechanical pump. Since your friend has an lg4 im gonna assume it's got a carb on it, some Lo3's Ive seen go either way. Electric fuel pumps can suck sometimes.
BUZZZZZZZZ.
SSC
[This message has been edited by SSC (edited December 01, 2001).]
BUZZZZZZZZ.
SSC
An LO3 without the mechanical fuel pump boss cast and machined into the block?
That's a new one on me.
