Fooling a knock sensor
Old Nov 18, 2005 | 09:58 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
Is there any way to fool a knock sensor. It is retarding my timing when I try to pass somebody. The motor has some piston slap that is causing the problems.
Old Nov 18, 2005 | 10:25 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
piston slap? You could fix that, that would "fool" the knock sensor
Old Nov 18, 2005 | 10:43 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
Yes, I know but I put this motor together a year ago. I bought it with two cracked heads, I was on a budget and just bought different heads, ringed it and put bearings in it. I should have bored it out and put new pistons in it. It was fine for a while, but know it is a real turd. I was hoping to get by for a while.
Old Nov 18, 2005 | 11:20 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Have you tried unplugging the sensor?
Old Nov 18, 2005 | 11:34 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
I have not, I was told that if it was unplugged the computer would set the timing retarded.
Old Nov 18, 2005 | 11:37 PM
Lo-tec's Avatar
Try it and see what happens. Hard to believe it will retard the timing without a signal. Mine didn't, and didn't give a check engine light with it disconnected.
Old Nov 18, 2005 | 11:50 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
I will give it i shot, got nothing to lose. But if it doesn't work, do you know of any way to bypass it.
Old Nov 19, 2005 | 12:00 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Don't unplug it. That won't do **** for you... make your problems worse, actually. It will kill almost ALL timing advace and it will pour fuel in. Like, eye burning rich. Not good. Its called "limp home mode" and its just that... limping around.
Really, the only solutions are to either fix the piston slap issue, change to aftermarket EFI that doesn't use a knock sensor, or change to a carb.
Old Nov 19, 2005 | 12:12 AM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
How does the sensor work, does it rely on voltage, resistance?
Old Nov 19, 2005 | 02:41 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Take the sensor out and coat it in teflon tape. It releys on voltage. It actually creates a voltage based on how much it vibrates.
Old Nov 19, 2005 | 07:10 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The BEST fix is to retune the Knock Sensor's specifications in the eprom. FYI, on most stock or basically stock TPI cars, the KS pulls out a TON of timing in WOT. I have found disabling or limiting the amount of timing pulled out when in WOT and then re-working the spark curve makes a lot more power.
PS: Don't unplug the KS. You'll only trigger the SES and cause the ECM to go into "Safe Mode" (and the engine will not perform properly as this is considered a major fault and the ECM is trying to get you home so you can fix the problem).
Old Nov 19, 2005 | 08:31 AM
Lo-tec's Avatar
Is this a TPI car or a CC Q-jet? I've disconnected it on my carbed setup and didn't recieve any codes and it didn't run different either. I've heard of wiring in a resistor inline to decrease the sensitivity, but couldn't tell you what value to use.
If this is a carbed car, from the 84 manual:
Loss of the ESC knock sensor signal of loss of ground at the ESC module would cause the signal to the ECM to remain high. This condition would cause the ECM to control EST as if no spark knocking were happening.
Old Nov 19, 2005 | 02:21 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
It is a vortec motor with the vortec intake out of a 98 van.
Old Nov 19, 2005 | 02:38 PM
Lo-tec's Avatar
What ecm and harness is being used to control the fuel injection?
Old Nov 19, 2005 | 02:41 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
The one from the van.
Old Nov 19, 2005 | 02:45 PM
Lo-tec's Avatar
You need software to hack the ecm. It's OBDII, I don't know off hand what software you would need (like LS1edit, LT1edit, etc.) You might want to try what dankhound said. Screw it in just past hand tight to lower the sensivity to knock (just enough so it doesn't leak).
Old Nov 19, 2005 | 03:46 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
where can I get more info about changing the ecm. I am used to working on carbed cars.
Old Nov 19, 2005 | 05:27 PM
Car: Death Mobile
Engine: 666 c.i.
The software to work on OBDII systems are limited and expensive. Most is for the higher performance cars such as the LS-1s and LT-1s - you may be out-of-luck for the Van.
You might want to consider going with an older OBDI system like those used on our cars. The software is cheaper and widely known on the DIY Prom Board. The ECMs (if you went SD), is readily available from a wrecking yard as well the sensors and very reasonable prices. The wiring harness can be picked up from Painless.
Old Nov 19, 2005 | 05:29 PM
Car: Death Mobile
Engine: 666 c.i.
PS: By limited, I mean only a couple of companies - not the PCM or software has only limited features.
Old Nov 19, 2005 | 06:27 PM
Lo-tec's Avatar
Do you have to go through emissions? If not, a carb intake and distributor swap would fix your problem.
Old Nov 19, 2005 | 07:02 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
What if you just pulled the knock sensor and wrapped it in foam and just tape it to something in the engine compartment...
Really trailer park boys style but it would work wouldnt it?
Old Nov 19, 2005 | 07:55 PM
Car: Death Mobile
Engine: 666 c.i.
As soon as I get my grade 10 and out of jail, I'll give it a try...
Old Nov 19, 2005 | 07:57 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Sounds good ricky
Old Nov 19, 2005 | 11:01 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
Thanks everybody. I think I'm going to try the foam and tie it out of the way trick.
Old Nov 19, 2005 | 11:03 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Im a genious, pure genious
Old Nov 19, 2005 | 11:31 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
Old Nov 20, 2005 | 12:03 AM
Air_Adam's Avatar
Old Nov 20, 2005 | 12:20 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Old Nov 20, 2005 | 12:21 AM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
but I want to try something simply before I have to tear it apart.
Old Nov 20, 2005 | 12:38 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
That would be funny if you hit a speedbump and it shut your engine down
It wont happen but it would be funny as hell.
Old Nov 20, 2005 | 12:53 AM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
