Spark Plugs
Car: 86 Firebird, 2002 Monte Carlo, 91 v
rapid fires perform anybetter with a stock hei? I used to have them in my fiero that was mostly stock. I liked them, but I don't know if I could tell a difference.
Car: 91 formula
Engine: 350 tuned port. bolt ons
you will not feel anything unless you car has big power or your plugs are bad and you replace them with rapid fires. I put them in because i have headers and they will last longer then stock ac delco. i hear good things about them all the time
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I used boch 4 tip ones and they were great. Now I am on my AC delco set and they are good but not as good as bosch.
Will try to use the rapid fire next.
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Champion copper plugs is what I have, no problems yet
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
