New timing chain seems tight
Old Nov 19, 2005 | 05:37 PM
Fbody fan 35yrs's Avatar
Car: 91 Z/28
Engine: 5.0
Transmission: T-56 6 speed
I started assembling my 91 L98 today. I bought a new S.A. Gear dbl roller timing set for it, and the chain seems very tight to me. I checked and the part number on the box isn't for a aline bored block or anything. I can move the chain from side ...... a little....... but don't feel any slack at all. Any thoughts?
Old Nov 19, 2005 | 05:56 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I put a Cloyes true roller on the engine I built and it was REAL TIGHT! I couldn't move the chain by applying light (less than 10 lb) pressure. I think they allow for the chain breaking in and make them that way so they won't have slack after they break in.
Old Nov 19, 2005 | 05:59 PM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
Sounds normal to me as long as you can rotate the bottom end without any binding or rubbing sounds. I just refreshed my 305 and put a new timing chain with the stock gears and it was tight. I have been driving the car with no problems. The old timing chain when tearing the motor down had enough slack that I could almost pinch the chain together between the gears.
Old Nov 19, 2005 | 06:03 PM
Car: 91 Z/28
Engine: 5.0
OK, Thanks Supervisor42......... I did a search and found a few others with a tight chain to start with. Everything rotates fine, so I guess I won't worry about it. It is a "true roller" chain, but wasn't the most expensive chain out there. Any one else ever use an S.A. Gear product?
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
