No key, what to do?
Old Dec 2, 2001 | 12:28 PM
Adams87Camaro's Avatar
No key, what to do?
Well yesterday up at the mountains i was snowboarding and somehow lost my keys somewhere on the mountain, i didn't take my car so its safe at home, i have duplicates of the '87 so i'm okay there. However i do not have duplicates of the '76 I have the original service manual also, isn't there a key code in there or something? could i take this key code to the pontiac dealership and have them make me a new door key and ignition key? Or is the car too old? Please help guys i have some bad luck!
'87 Sports Coupe Camaro
-305 4bbl (LG4)
-flowmaster catback
-free mods
'76 Firebird
-355
-mild isky cam
-hooker headers
-mallory ignition
-edelbrock torquer II intake
-carter 625 afb
-eaton 3.73 posi rear end
-B&M shift kit
Old Dec 2, 2001 | 01:07 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I don't think there is a key code in the service manual. I have seen locksmiths cut keys on the spot (trial and error). I watched it before. They stick the key in, file some off, stick it back in, file more off, and so on till it works. It may not be a 100% match, but it will get the lockcylinder turning so it can be replaced w/ a new one and a matching key.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 2, 2001 | 01:33 PM
how much does that usually cost?
Old Dec 2, 2001 | 01:35 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
No idea. I have seen it done, never actually needed it. I'd call a locksmith and explain what happened. See what they say.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 2, 2001 | 02:19 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I had a guy make me a set of keys for a car I bought that had none..(lean sale)
cost $20.00 no reciept.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Dec 2, 2001 | 05:10 PM
well i just had the locksmith come down and put in a new ignition switch cost me $55 however he wants $170 to do the door cause he said since i don't have a locking glovebox he has to get the lock from the door and that makes it hard because he has to take apart the entire door, is there anyway else to do this?
Old Dec 2, 2001 | 05:25 PM
Vader's Avatar
Yes. Go to a parts store and get a set of OEM replacement locks for your car for about twenty bucks, then install them yourself.
At least you only have two doors and a hatch. I did this once on an Astro van, with all the friggin' doors. That shot that afternoon...
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Dec 2, 2001 | 05:58 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, do the doors yourself. You don't need to rotate the door cylinders like you do the ignition cylinder. Parts stores usually sell a pair of cylinders w/ a pair of keys.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 2, 2001 | 07:48 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by Adams87Camaro:
well i just had the locksmith come down and put in a new ignition switch cost me $55 however he wants $170 to do the door cause he said since i don't have a locking glovebox he has to get the lock from the door and that makes it hard because he has to take apart the entire door, is there anyway else to do this?</font>
Dude, find a real locksmith.
The guy did my doors in about 15 minutes, and the door was locked, no way to open it.
Sounds like this guy is either pulling your leg, or doesn't know jack.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Dec 2, 2001 | 07:51 PM
breathment's Avatar
nevermind
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited December 02, 2001).]
Old Dec 4, 2001 | 03:18 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Replacing the whole lock is going to be the cheapest way to do it. I had to re-do the doors and ignition on my SafariWagon when I lost they keys. I ended up having three keys because the tailgate lock was a special piece. Once you can get in to the car, it should only take a couple hours, max. As a bonus, you will have all new, smooth operating lock cylinders.
Old Dec 4, 2001 | 08:40 AM
88firebird305's Avatar
Don't we (well I do) have a locking box in the hatch that uses the same key as the door?
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
