what is the clicking noise on column when i push the button on shifter? WEIRD
Old Dec 4, 2001 | 09:23 PM
breathment's Avatar
I was sitting a stop light tonight, and i was bored, (as i usualy am because i drive way to much), and i was playing with the button on the shifter. and i was pushing it and and out and in etc. and i started to notice that everytime i let the button out i would hear a pretty loud click in the steering column, loud enough to be heard with stereo on and windows down. is this some sort of relay or test thing that keeps u from shifting unless the key is in the "ON" position?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Dec 4, 2001 | 09:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's the park lock cable that keeps you from pushing the button unless the key is in the on position.
Old Dec 4, 2001 | 09:40 PM
Vader's Avatar
Breath,
You and I must be clones. This used to bug the crap out of me, too. Wondering just what the heck the interlock was all about, I started to dig into it one day. The best I could determine without disassembling the upper bowl of the column was that it is the key release interlock solenoid. I used to think it was the rear hatch release interlock, but I could get the hatch to release with the button depressed as long as the park brake was engaged.
You can experiment like I did. Without driving the car, insert the key and turn the ignition to RUN. Depress the lock button on the gear selector to make the noise. Try turning the key to the OFF position or LOCK position. You cannot turn the key to the full LOCK position unless you release the key, then turn it back again.
I think this feature was intended to prevent locking the steering column while the transmission was in any position except park, in case the key was inadvertently shut off while the vehicle is moving. Don't ask me how, but just when you try to make something idiot-prrof, they'll find a bigger idiot. At best, things can only be engineered to be idiot-friendly, not idiot-proof.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
383cam
Sep 9, 2015 06:01 AM
Randomtask2
Sep 7, 2015 05:06 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
