Any porting kits work with dremel?
Old Dec 2, 2001 | 11:24 PM
cort351w's Avatar
SA says theirs doesn't.
Does this one?
http://www.eastwoodcompany.com/cgi-bin/sgin0101.exe
should work, but if that doesn't work, go to http://www.eastwoodcompany.com/ and search porting
Any others?
Haven't looked at dremel tools; are there comparable bits made for dremel?
I don't have air, so I need to use my dremel.
Old Dec 3, 2001 | 12:51 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
SA and the porting bits on Eastwood are all 1/4" shaft/mandrel. Dremels are typically 1/8" or 3/32" collet - too small.
Some of the bits and the like are available in Dremel size. But, Dremel makes things for small, precise work rather than the virtual "hogging" you have to do in porting. Polishing those large surfaces would also be a challenge. SA does talk about electric driven motors, but don't really endorse their use.
For the cost of a good electric system, you could probably get an air compressor (especially used) and diegrinder to do the job. You'll also have an air compressor to use for other things after that.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Dec 3, 2001 | 01:51 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Maybe you can rent the air driven stuff, too. It's gotta be a lot cheaper than buying it outright
I've gotta a dremel here, as well, and was disappointed to find it won't work either.
Old Dec 3, 2001 | 05:25 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I used an air driven die grinder to initially port my heads, but to port match my heads and manifold, I used my dremel. You don't need a specific kit. Dremel, and other companies make many different bits that you can use.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Dec 3, 2001 | 09:18 AM
Damon's Avatar
Your Dremel will have it's tongue hangin' out by the time you finish the first port! They just don't have the "Wheaties" to get the job done. Air powered die grinder is the only way to fly, IMHO.
Old Dec 3, 2001 | 11:09 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
If you do use a dremel, you might wanna pick up a couple extra sets of motor brushes. Those things wear out quick under heavy use. Ive already replaced mine twice.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Dec 3, 2001 | 08:19 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Just to give you an idea of how much a Dremel sucks at porting heads, I can tell you that I've tried it.
I used the different stones that you can buy for the Dremel. I got ONE port done, and the stones were about half the size they were when I started.
Plus it took forever!!! And I was only pocket porting. It worked well for removing the casting ridges in the runners and around the edges of the openings, but I'm now going to wait until I get a die grinder.
AJ
[This message has been edited by AJ_92RS (edited December 03, 2001).]
Old Dec 3, 2001 | 11:03 PM
cort351w's Avatar
Sorry, I should have specified--I will only be porting the tpi plenum, runners (maybe siamesing), and base right now. I'll be going out of town and won't have time to do my exhaust, tpi port, and tpi polish and also do the heads. Why am I doing the tpi and not actally getting performance by doing the heads? Because I only have a dremel right now.
[This message has been edited by cort351w (edited December 04, 2001).]
Old Dec 4, 2001 | 09:50 AM
gravitar's Avatar
Dremels are only good for engraving your initials into tools, or cutting off a bolt head when you don't feel like firing up the compressor
Actually, there are heavy-duty electric die grinders.. Du-more is a name that comes to mind. They're big $$ though, and much larger than a dremel.
I agree with the previous recommendations about getting a small compressor and running an air die grinder. Once you have a compressor, you'll never know how you lived without it!
Old Dec 4, 2001 | 10:53 AM
AJ_92RS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by cort351w:
Sorry, I should have specified--I will only be porting the tpi plenum, runners (maybe siamesing), and base right now. I'll be going out of town and won't have time to do my exhaust, tpi port, and tpi polish. Why am I doing the tpi and not actally getting performance by doing the heads? Because I only have a dremel right now.</font>
Well if the stuff you're gonna do is aluminum, then a Dremel will work fine.
But you gotta know that with aluminum, you don't want the finish to be "baby butt" smooth. I forget the reason now. But I know that SA even tells you to use the 400 grit roll on aluminum, but not the 800. I think the fuel will condensate up, then run together into a pool, then drip into the runners. Something like that. I can't remember exactly.
AJ
Old Dec 5, 2001 | 12:36 AM
five7kid's Avatar
<font face="Verdana, Arial" size="2">Originally posted by AJ_92RS:
AJ
</font>
No, that's not because of the aluminum, that's for wet intake systems. As in carb or TBI.
TPI is a dry system, so at least until you get to the port in the heads, mirror smooth is good.
Jeremys87
Jul 14, 2022 09:08 PM
Terrell351
Jun 13, 2021 01:13 PM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
mx127
Aug 10, 2015 08:13 AM
