Vortec 350,what`s the best crank?
Old Nov 25, 2005 | 07:31 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys,my boss want to sell me a 99 vortec 350 engine from a 2500 silverado,it is a very low mileage motor as far as I can tell(there is still cross patterns in the cylinder walls)he only wants 200 for it, but the problem it has is a cracked crank,I have completely looked over this engine and everything else appears to be in very good shape,what would you guys recommend for a good strong crank.I want to be able to spray this engine and get some good rev capabilities from it,any good suggestions guys?
Old Nov 25, 2005 | 07:37 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Well....I mean....it's pretty damn hard to break a crank, lots of guys go way far on stockers.... I'd love to know what in the hell he did to break it in the first place!
Old Nov 25, 2005 | 07:45 PM
he didn`t break it,it was pulled from one of our customers trucks because it was knocking.the crank is popped in two places.Luckily all the mains are in great shape and the bearings have almost no evidence of any major wear.so hopefully everything will be fine .
I`ll try to get pics this weekend so I can show everyone.
Old Nov 25, 2005 | 07:59 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
best crank? Callies For what you want though, eagle or scat would get you by just fine.
Make sure you go over the block with a fine tooth comb. If it broke a crank, look for signs of heat on the bearing saddles and also go over the rods/pistons. Something could have been out of balance and the harmonics probably ate the crank.
Old Nov 25, 2005 | 08:03 PM
should I get the whole rotating assembly or just the crank and have everything balanced together?what would be the best option,I don`t want to be a turd but I just want to do this right the first time.
Old Nov 25, 2005 | 08:04 PM
busted here,not the same crank but just to give you an idea.
As far as the balancing being a problem that was my first thought.maybe the flexplate and H.B were out of wack.
Old Nov 25, 2005 | 08:27 PM
Dialed_In's Avatar
If you're on budget I would get an eagle rotating assembly and build an N/A motor. You can get them balanced too. If you've got some extra cash go for the kit with the 4340 crank and rods. Also comes with JE pistons. Sent you a PM
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
Eric-86sc
Aug 24, 2015 09:01 PM
BBSDesigns
Aug 11, 2015 07:39 PM
