Stock Deck Height?
Old Dec 7, 2001 | 10:37 AM
tpi_roc's Avatar
Stock Deck Height?
Does anybody know what the stock deck height is on a 9.5:1 L98?
Also the gasket thickness compressed on the stock gaskets.
Thanks!
1985 Iroc-z, 14 second 305, new engine in the works.
Old Dec 7, 2001 | 11:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
9.025" from crank centerline to deck
If you're talking about deck clearance which is what it looks like you want to know about, it's .025" ± .005". Stock gaskets are about .039" thick.
ICON Motorsports
Old Dec 7, 2001 | 11:10 AM
Damon's Avatar
Pulled apart an '87 L-98 a few months back and the gaskets were old-style steel shim gaskets. Those are usually very thin- .018" or so.
If you run the numbers (just did it myself) you will hit a compression ratio of about 9.45:1 with a .025" deck clearance, stock 12cc dished L-98 pistons, 64cc combustion chambers and the afore mentioned .018" head gaskets. That's very close to advertised compression on this motor. Put .039" head gaskets on the same combo you get 9:1 which is very far from advertised.
Old Dec 7, 2001 | 11:11 AM
tpi_roc's Avatar
Piston to deck
sorry for confusions.
Dang, so GM didn't screw around with tight clearances...
Spose I'll be deck'n the block
thanks!
Old Dec 7, 2001 | 11:16 AM
tpi_roc's Avatar
Damon! thanks a ton, very helpfull!!!
Old Dec 7, 2001 | 11:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
My bad... didn't realize they used shim gaskets in those, most factory motors I've pulled apart have had red Victorcore gaskets.
ICON Motorsports
Old Dec 7, 2001 | 11:24 AM
tpi_roc's Avatar
No bad, all is appreciated.
Ok, say that in building/blue printing an engine the gasket thickness is a variable, are there any considerations with gasket sizes? (not talking compression/quench) Like do thicker gaskets blow? thinner ones? materials they're made of stronger/ weaker?
Give me some gasketology
Old Dec 7, 2001 | 11:30 AM
Guest
Guest
Posts: n/a
Thinner gaskets are usually just a thin piece of metal and have alot more tendency to leak. If you deck the block and cut the heads though, there should not be any sealing problems.
Old Dec 7, 2001 | 12:50 PM
tpi_roc's Avatar
Is compression height how I would find my deck clearance with a new set of pistons?
If not, how so?
[This message has been edited by tpi_roc (edited December 07, 2001).]
Old Dec 7, 2001 | 01:02 PM
tpi_roc's Avatar
Nevermind
figured it out
customblackbird
Aug 15, 2021 10:16 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Genopsyde
Oct 7, 2015 08:35 PM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
sailtexas186548
Aug 26, 2015 03:32 PM
