help me ID a cam
Old Nov 29, 2005 | 09:04 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
help me ID a cam
i pulled it out of this motor i bought, it says EP1 on teh cam and on the back of the cam (dizzy side) it has 4 white dots in a row. is this of any significance?
Old Nov 29, 2005 | 10:48 PM
BadSS's Avatar
EP1 is a term Federal / TRW / Speed-Pro uses to designate that the cam is "one step up" from stock. Don't know the specs off the top of my head,,,, but it should be small duration low lift (and obvious)--- IF thats what it is.
Old Nov 29, 2005 | 10:50 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well thats lame. think their is any way to ID this any further?
Old Nov 29, 2005 | 10:57 PM
Guest
Guest
Posts: n/a
204/214 .420/.443
I'll bet thats it. I had a Melling IIRC it was MTC1 or EPC1 or something like that, and thats the specs of that cam. Its basically a lame duck cam, although you can make a little more power than stock with it. Some people do well if the other components are well matched.
Got a mic? Measure the lobes. Measure the base circle (smallest measurement) and the top of the lobe (largest measurement). Subtract those. Thats the lobe lift. x1.5 for valve lift.
BTW you need a cam? PM me. I have a few I dont need. Tell me what you are putting it in, I dont know. And you probably dont remember but I met you at Nojoqui briefly after you finished the scenic route.
Old Nov 29, 2005 | 10:59 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks, as an unused cam, think i can get ANY money for it, being a flat tappet, and i would be including new lifters too.. heh
Old Nov 29, 2005 | 11:01 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
also what kind of LSA do these cams typically run?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
