hows this setup looking?
Old Nov 30, 2005 | 12:09 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
4bolt mains one peice RMS. -zero decked
383
eagle cast steel crankshaft 3.75" stroke
6" forged I beam rods
KB Hyp flat top pistons w/ 2 valve reliefs. -7cc
64cc canfield heads 2.08/1.6 valves.
stealth ram.
30# injectors.
hedman shorty headers.
im guessing this is aprox 11:1 CR
ill be custom tuning this myself.
whats your opinions on this setup? i have it all already just needs to be assembled now.
how well do ya think i can do at the track?
Old Nov 30, 2005 | 12:35 AM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
Are you getting the balanced rotating assembly from eagle?? That set up that you are talking about is very similar, or could even be the same as the one I have. The only thing that I have had a problem is clearance issues between the SIR I-Beam rods with the cam. I returned the old cam and ordered a small base circle (1.050” base) and I am just waiting for it to get here so I can put it in (hopefully by next weekend). I hope that it fixes the problem but if it doesn’t then I’m going to have to take a little off the bolts. To avoid this problem all together you could get the ESP 3-D connecting rods but there like $300 more bucks!! But that set up will kick a**, can’t wait till mine is running. So what happened to your motor I see in big letters on your sig that it blew up!? What happened? Well I hope this helps out.
Old Nov 30, 2005 | 12:48 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
its not the eagle rotating assembly, i peiced it myself, i dont even know if the cam is gonna clear the rods yet havnt stuck it in so that may change. i just really dont know which cam is good for a 383
Old Nov 30, 2005 | 12:56 AM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
That’s cool that your going to piece it together, I think that my cam is a little too small for a 383 but I think it will do for now. Let me know what cam you do decide to go for. O and one more thing are you going to balance the assembly yourself or are you going to take it to a shop. I’m thinking that it would be best for you if you assemble the assembly including the cam to see if everything clears and if it doesn’t you can get it cleared and balanced all at the same time. It would suck if you had to balance your assembly twice which I might be doing. It might take longer but it could save you money!!
Old Nov 30, 2005 | 01:02 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
good point man! ill stick the cam in first and crank it all by hand to see if it all clears eh?
Old Nov 30, 2005 | 01:03 AM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
well i got to hit the sack im tired but good luck on that build and please keep me updated on what you do. later
Old Nov 30, 2005 | 01:13 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Scroll about 3/4 of the way down this post. I think youll see "blowed up" is just putting it mildly
https://www.thirdgen.org/techbb2/sho...hreadid=332668
Old Nov 30, 2005 | 01:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Old Nov 30, 2005 | 05:27 AM
ede's Avatar
ede
i think you need to get a cam or it isn't going to work at all
Old Nov 30, 2005 | 09:59 AM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
I just read about your motor dying on you. That’s really no good but at least you’re now going to a 383!!
Old Nov 30, 2005 | 01:38 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Old Nov 30, 2005 | 05:32 PM
A88GTANotchback's Avatar
sorry to hear man but i thik you gave me some insight as to my decsion...heads and cam on stock block this winter....or wait till rebuild....i think i may wait....good luck with the new motor.
Terrell351
Jun 13, 2021 01:13 PM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
stalkier
Dec 6, 2015 11:25 PM
L98GTA87
Aug 25, 2015 02:23 PM
Street Lethal
Aug 13, 2015 08:28 PM
